  • 1994 - 1995 Specific Tech
Thicker head gaskets?
  • Thread starter Thread starter 1105
  • Start date Start date Dec 30, 2004
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Dec 30, 2004
  • Dec 30, 2004
Does the Fel Pro 1011-2 headgaskets come in different thickness? If so what is the thickest? If it only comes in one size, does anyone know a company that makes a think gasket that doesnt cost an arm and a leg?
K
KM 94 GT
124
  • Dec 30, 2004
I take it as thicker headgasket to lower compression a bit for boost maybe? If so, doesn't Ford Racing or someone make a stackable type headgasket kit thats not too expensive? I think I saw it in the P.A.W. ad in MM&FF either there or on like Summit or something. I'll look again.
1105
May 3, 2003
3,841
Daytona Bch, FL
Dec 30, 2004
  • Dec 30, 2004
I dont want it to lower the compression, but I rather have a lower compression and be that much safer when it comes to piston to valve clerance
mytight95
2,605
Dothan,Al
Dec 31, 2004
  • Dec 31, 2004
i think cometic, and you can get a set of copper gaskets, they are reusable a couple times, and you get them in different thicknesses, one piece not stacking for like 100$ not too much more than a good set of the 1011-2's......
jason
C
CopMagnet5oh
64
  • Dec 31, 2004
why are you going to lose compression for nothing when u can just check the p/v clearance and get proper head gasket or flycut the pistons to the size. get every lil bit of power you can, dont waste it.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 31, 2004
  • Dec 31, 2004
Explain a bit more? Your running a TFS 1 cam. It obviously fits fine as you've been running it for a while now. Fwiw you can run a LOT "bigger" cams than you think with TW heads. My TW heads are milled .020" fwiw and I run an FTI cam.
1105
May 3, 2003
3,841
Daytona Bch, FL
Dec 31, 2004
  • Dec 31, 2004
As of right now I have 8 bent intake valves. What caused it I dont know, but I believe they went down and hit the pistons. I'm not exactly sure how or why, but all I know is I dont want it to happen again.
I talked to a guy that works for TFS and told him about my setup and he said its possible that I could have floated the valves and bent them that way. With my cam, he said I'd probably be floating the valves around 5500rpm so that is a high possiblity. But this will be a weekend project and I dont have time to drive an hour to and back to the nearest speed shop to get some gaskets so I would like to get thicker ones just to be on the safe side.
You say you think you can run a lot bigger cam with the TW heads... I've heard the opposite. Earnie is probably in the same boat as me. Hes running the Anderson B81? cam in his car and he believes somethings wrong with his car now.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 31, 2004
  • Dec 31, 2004
No, what I meant is its all in the valve timing as to how big your cam can be. Mines "bigger" than most would think is possible to run considering my heads are milled .020" as well. It does sound like you floated the valves. Although, when I ran the TFS 1 cam on stock springs I never had any issues. I do recommend upgraded springs definatly. Depending how long you can wait, i'd call up Ed C and order a set of his drop is replacement springs for TW heads. Thats about $120. They go right in and you can reuse the stock locks and retainers. I upgraded mine when I got one of his cams. I personally would use a cheap fel pro 9333pt-1 head gasket and call it a day. Definatly upgeade the springs dude. I did mine with the heads on the car and it wasnt too bad. Its a cake job with the head off.
You have any track times?
1105
May 3, 2003
3,841
Daytona Bch, FL
Dec 31, 2004
  • Dec 31, 2004
I have springs from the R heads ordered. The guy I talked to designs parts for TFS and he recomended I run thoes springs.
I ran a 13.5 @ 102mph first time at the track with my current combo, un tuned, stock MAF and injecros.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 31, 2004
#10
  • Dec 31, 2004
  • #10
Are those springs gonna fit w/o any machine work?
1105
May 3, 2003
3,841
Daytona Bch, FL
Dec 31, 2004
#11
  • Dec 31, 2004
  • #11
They'll fit just fine and I'll be able to reuse the stock hardware
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
