Thinking about a cam swap.
  • Thread starter Thread starter 68EFIvert
  • Start date Start date Mar 14, 2009
68EFIvert
639
Camas, Washington
Mar 14, 2009
  • Mar 14, 2009
I am running a FMS E303 cam now and am making 402rwhp and 414 rwtq. I cam across a deal that I could buy an Anderson Ford Cam B-21 that would go well with my 1.7rr. Do you guys think it would make a noticable difference in power. Would it be worth it?
10secgoal
2,801
San Diego
Mar 14, 2009
  • Mar 14, 2009
Eh, I'd look at your IAT's first. If you could give it more boost, I'd do that first. Pulling the cam, a head ( to check Piston to valve), and putting it all back seems like a pain for even a 50 hp gain.
68EFIvert
639
Camas, Washington
Mar 14, 2009
  • Mar 14, 2009
IAT's? Is that intake air temp? How would you check that? Are you suggesting a Methanol Injection kit rather than a cam swap? Thanks for the help.
10secgoal
2,801
San Diego
Mar 14, 2009
  • Mar 14, 2009
yep, inlet temps. You can put a gauge in the manifold to see what's going on. If it's not bad, and you can up the boost and pick up, or methanol if need be. But the tune should be cheaper also since he only needs to add cells for the extra boost rather than changing more, for a new cam. Just a thought.
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
