  • 1994 - 1995 Specific Tech
Thinking about going EFI
  • Thread starter Thread starter mustangman33
  • Start date Start date Sep 25, 2004
M
mustangman33
262
Chicago, IL
Sep 25, 2004
  • Sep 25, 2004
Got a carbed 351w in my car now, and since Ive been on stangnet been considering switching to efi over the winter, Im thinking about going to the bone yard and finding a efi 150, taking the computer, wiring harness, sensors, lower/upper intake, etc., will this work, would I be able to be setup like a 5.0 efi even if its an older efi setup.
95Cobra302
394
Daytona Beach, FL
Sep 25, 2004
  • Sep 25, 2004
You'll need a new upper intake, the truck upper intake is way to tall.
M
mustangman33
262
Chicago, IL
Sep 25, 2004
  • Sep 25, 2004
Cant I use the 5.0 upper, and do I have the right idea about the swap, just thougt bout somthin, cant I get all of the efi stuff from a 5.0, and just use a 351w lower intake.
M
mackey
1,284
Beverly, Massachusetts
Sep 25, 2004
  • Sep 25, 2004
The 5.0 lower isn't wide enough. You might be able to use the upper, but I KNOW the lower must be changed.
95Cobra302
394
Daytona Beach, FL
Sep 25, 2004
  • Sep 25, 2004
Oh I thought you were putting the 5.0L in the car. The windsor is wider so the 302 intakes won't work. Most everything should swap over, you'll have to use a truck lower manifold and an edelbrock or trick flow upper.
M
mustangman33
262
Chicago, IL
Sep 26, 2004
  • Sep 26, 2004
thanx for the replies, nother question, will I need all of the efi stuff, like all of the sensors, can I just get all of the fuel and air parts, like tb, injectors, o2 sensors etc., or will I need everything to go thru the cycle.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 26, 2004
  • Sep 26, 2004
Every thing is needed so the computer can make the proper adjustments. If your at WOT and don't have the sensor how is the computer know to dump more fuel to mix with the added air. Besides it would run like crap if you did have all the sensors working.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 26, 2004
  • Sep 26, 2004
Disregaurd my post I read your question wrong. Sorry now that I think about I don't see why not.
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Tuesday at 10:55 AM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 1:54 PM
limp
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
P
Engine Swapping EFI distributor for carb distributor- shaft length is different
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 21, 2024
pindude80
P
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
