Thinking about Injectors
  • Thread starter Thread starter saleen880
  • Start date Start date Jun 2, 2010
saleen880
9
  • Jun 2, 2010
I recently had my car dynod 480hp on a ****ty tune,and they told me my injectors are at 100% maxed out and said i need 42lb injectors, currently running 30lbers with fmu and 255 pump,my question is Will my fuel pump supply enough fuel without a booster pump and is it even worth going to a 42lb injector.....just seems like a lot of fuel and i dont want to waste my money thanks
M
Mike in Texas
121
  • Jun 3, 2010
480 rwhp = ~560 fwhp = 48# injectors (for forced induction). Even with the fmu I don't see how you're fueling that much hp (would take ~100 psi fuel pressure). Even with the 42's you would still need the fmu.
check this site Fuel Injector Calculator from WitchHunter Performance
Onefine88
Previously 89SSC18
1,422
796
154
Jun 3, 2010
  • Jun 3, 2010
My SSC makes 441rwhp. I've been running a #GSS-340 255lph pump for years. ( No booster pump).
I'm using 42's with no FMU.
No problems, my A/F ratio is perfect all the way to 6K redline.
With a good tune you'll be fine.
saleen880
9
  • Jun 3, 2010
thanks for the help....I went from 24lbers to the 30lbs any didnt really notice a difference...that why im kinda wondering if i would be wasting money, and do any of you have any kind of drivability issues with those injectors, and btw my fuel press does go over 100
7upstang91
936
124
74
Florida
Jun 4, 2010
  • Jun 4, 2010
Oh man, you do need at least 42lbs! You should probably go to 60s to be on the safe side, if you want more power. 100% maxed out is not good, no matter how good the tune.
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
Engine Light throttle miss
  • Dontknowchit
  • Jul 7, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
AeroCoupe
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
