thinking about stroker but have questions ??
  • Thread starter Thread starter 2002BLGT
  • Start date Start date Sep 28, 2005
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Sep 28, 2005
  • Sep 28, 2005
It will be in a daily driver , so first question is this , all the stroker kits I see are for 28 oz balancers , what flywheel should I get to run with the T5 and I am trying to do this cheap so do post something that cost 500 bucks please LOL ???? Plus what balancers will work with my stock pullies and etc ???? if you guys can post some part numbers and prices for me , everything else I pretty much have figured out what route I am going to go with , but if the other things I am going to need cost alot I might just build a 306 and let the stroker wait till the next time I build something ......
J
jerryD
1,061
Gladstone, MO
Sep 28, 2005
  • Sep 28, 2005
cheap and stroker usually don't go together. i don't know of any stroker kits going for $500. when you order your kit, you can specify what balance you want i.e., 28, 50 or even 0oz. for the T5, you will need a 157t flywheel. talk to brain at www.adperformance.com and he will get you staight. he won't try to sell you something you won't need. you can spend anywhere from $900 to $1300 for a rotating assembly.
my advice, talk to brian about what parts come in his kits, get part numbers and get the info your self that way you can make an informed decision on your own, not from what everyone else tells you.
bubba-dough
1,044
Indiana
Sep 29, 2005
  • Sep 29, 2005
Coast High Performance has 347 kits for $799. http://coasthigh.com/Specials/Specials_current.htm And the stock balance is 50 oz. Any place can give you whatever balance you need. I built my 347 for a few hundred dollars more than a 306. So I would recommend going stroker rather than a 306. Anyway you go you will need heads, intake, injectors so on and so forth. And as far as machining the only difference between the 306 and the 347 is the bottom of the cylinders need to be clearanced (notched) for the stroker.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 29, 2005
  • Sep 29, 2005
You can have your 347 assembly balanced to 50oz though its not ideal. I would NOT use a stock balancer on a 347. At least pick up a decent sfi balancer. Your budget of $500 doesn't seem like its gonna do much in terms of a stroker. I just did one, it cost a hell of a lot more than $500.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Sep 30, 2005
  • Sep 30, 2005
I was meaning 500 dollars in extras needed to make it work ......
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
