  • SN95 4.6L Mustang Tech
this is a PATS issue right?
  • Thread starter Thread starter predator_96817
  • Start date Start date Apr 21, 2007
P
predator_96817
133
  • Apr 21, 2007
ok...im driving on the highway and my car dies. I pull to the side of the road and the car wont start. theft light blinking in ON position...car turns but wont start. I also see the service engine and battery light on too. is that normal? everything else thats electrical seems to be working fine. another thing i noticed is that the odometer is showing ------- instead of numbers... i havent checked the fuses yet, but ill check all of um. could this be the result of some kind of short? is this a PATS issue? if it is, do I have to bring the car down to the dealer? BTW i dont have a spare key..bought the car second hand and never got a second key.
ToplessStang
591
Montreal, Canada
Apr 21, 2007
  • Apr 21, 2007
Once the car has started the PATS system should not come into play until the next time you start your car. Sounds like a PCM or cluster issue.
Checking your fuses is a very good first step.
P
predator_96817
133
  • Apr 21, 2007
the car does not start anymore..it just turns over.
just checked the fuses..gadzuks!! it was a blown PCM fuse.. you were right . i hope all i gotta do is replace it...
brent_cosenza
70
Georgia
Apr 21, 2007
  • Apr 21, 2007
predator i have had the same problem where is the pcm fuse
P
predator_96817
133
  • Apr 21, 2007
i just changed out the fuse and everything is hunky-dory. I think i know where a short might have come from...one of my wires going to the maf is rubbing on a sharp piece of metal.. when i looked at it.. the metal had cut through the plastic covering and was touching the wires inside. at least i think thats the problem.
as far as the pcm fuse...its fuse number 26. when you open the fuse box in the engine its the green fuse near the bottom left (if you are standing on the left side of the car facing the engine) it should be right above a yellow fuse. its the big fuses btw. refer to the manual
ToplessStang
591
Montreal, Canada
Apr 22, 2007
  • Apr 22, 2007
Good job
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Resolved 1996 PATS help needed
  • Bajaboy
  • May 21, 2025
SN95 4.6L Mustang Tech May 23, 2025
Bajaboy
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
D
Theft light staying on car starts right up
  • dtarang
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 15, 2026
dtarang
D
