I'm just about to sell the stang as some of you know for a 94-95 and put in a 351. Just curious if there are any of you that have sold your 4.6 and really regret it.
I sold my 4.6L because I didn't like making the payments anymore.
If you look at the 4.6L it is quite simple to work on...just take a look
The headers are the only "real challenge" compared to the 5.0L.
I've seen engine builders actually say the 4.6L is easier to work on once you get past the intake...
Just remember the 99+ 4.6L platform has more than just engine enhancements done to it...everything is better than a stock 5.0L.
had a 94 Tbird with a 4.6 DOHC
Swarzkopf said:I had one and took plenty of looks. It scared the **** out of me. It's not easy to work on for your average home wrench turner, period.
Swarzkopf said:Would you try swapping heads on a 4.6 car? I wouldn't.
Swarzkopf said:I wanted to spray mine and couldn't even get a nitrous kit because of the returnless fuel system.
Swarzkopf said:Yeah, I've heard the same thing, not only from engine builders, but from quite a few big horsepower guys...but these are guys with professional grade shops with professional grade tools and equipment, with a skill set far greater than my own.
Swarzkopf said:For guys like me, the 5.0 is easier.
Swarzkopf said:Eh? Care to elaborate? I was under the impression that the chassis and suspesion was the same from 94-04...?
t45 transmission - a bit tougher than the t5.
Starting in 96 - Revised rack and pinion steering system for sharper turn-in and response.
17in. wheel and tire package.
new front crossmember that provided more rigidity and strength and also helped revise the suspension geometry for less understeer. The 96 Gt's also got a larger 24mm rear stabilizer bar and revised shock absorber tuning.
Now I have had a 00 GT and a buddy of mine has a 98 gt and a 95 gt. The 00 GT out handled them. The 98 even has steeda arpings.
The 99+'s also have bigger brakes and I'm sure so more was revised in the suspension department from 98-99 if they were from 95-96. I don't know the specifics but I'll look into it if you want
Swarzkopf said:had a 94 Tbird with a 4.6 DOHC
What?
