  • SN95 4.6L Mustang Tech
thread locker
  • Thread starter Thread starter ADRENLN
  • Start date Start date Dec 26, 2003
ADRENLN
2,342
NJ
Dec 26, 2003
  • Dec 26, 2003
guys i was wondering if there is anything to remove lock-light the thread locker from a bolt. i used it on a bolt on my shifter and i just wanted to see how you guys maybe soften that stuff up. i didnt think it worked so good that thing is really stuck. thanks for any ideas.
cybore
160
San Jose, CA
Dec 26, 2003
  • Dec 26, 2003
I don't know about this, but I'll bump ya since you're about to go off the first page.
Did you use red or blue locker? The blue is used on parts you will want to remove later, red is for 'permanent' locking and is very difficult to remove the bolt.
nyuk98gt
1,427
Chesterfield, MO
Dec 26, 2003
  • Dec 26, 2003
ADRENLN:
Heat and a brass bristle brush will get the stuff out of the threads. I use a paint remover heat gun but a propane torch will work -- just be very careful because you don't want to overheat the fastener. Check the Loctite website, loctiteproducts.com, too.
ADRENLN
2,342
NJ
Dec 26, 2003
  • Dec 26, 2003
thanks for the ideas guys, and i used the permatex the green kind?
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
