So my roommate is dying to get my car running again. It's like he's more obsessed with my car than I am. So, while I was working on finishing the rebuild of my tremec 3550 transmission, which cost me like 1800 dollars
, he got busy putting my engine back together.
I'd bought a windage tray which came with a stud kit. He pulled four of the main bearing bolts and started installing the studs in their place. I was struggling with my memory trying to figure out how the shifter assembly went back together. So I took a break and watched Heath work the torque wrench. He was straining trying to reach the 125Ftlbs on the studs when there was a loud pop and he almost fell over when the wrench went slack.
He pulled the stud out and it brought 4 of the threads out of the block with it. That's not good, not good at all, but what do you do about that?
We discovered that only those 3-4 threads were engaged when he started putting the pressure on the stud. The original main bolts went like three times farther down into the block. So we backed the nut on the stud off till they had the same number of threads engaging the block as the bolts did.
He retorqued the stud in the damaged hole and it held 100FTLBs (we figured we shouldn't try for the 125, and the manual says to do it between 95-105 so hopefully we are within tolerance). So, maybe we got lucky?? Or is it going to fail on us when we put the power down?
I'm kinda scared, but Heath said the look on my face never changed. It's because I was trying to remain calm for him. If he thought I was going to have to replace the block he would have freaked out considering how long it'd take to get another one.
What do you guys think? Is the block hosed?
, he got busy putting my engine back together.I'd bought a windage tray which came with a stud kit. He pulled four of the main bearing bolts and started installing the studs in their place. I was struggling with my memory trying to figure out how the shifter assembly went back together. So I took a break and watched Heath work the torque wrench. He was straining trying to reach the 125Ftlbs on the studs when there was a loud pop and he almost fell over when the wrench went slack.
