  • SN95 4.6L Mustang Tech
Threw a code, P0190
  • Thread starter Thread starter FalconGuy016
  • Start date Start date Feb 23, 2006
F
FalconGuy016
437
Northern VA
Feb 23, 2006
  • Feb 23, 2006
I threw a code and read it today as "P0190", fuel rail pressure sensor malfunction.
I disconnected and reconnected what I thought was the fuel rail pressure sensor and erased the code. It didn't come back, yet, but has anybody heard of this? I'd rather not take it to the dealer if I don't need to.
imblown-ru
247
Roanoke VA
Feb 23, 2006
  • Feb 23, 2006
haha...man i just went threw hell with this code 2 days ago. Apparently they go bad every now and then, so we replaced it, and the code didnt come back but it wouldnt idle, it was running real lean. to make a long story short we wound up dropping the fuel tank and replacing a rubber o ring in the fuel pump can. It had a piece broken off of it, and was losing major fuel pressure. so anyways if your car is running ****ty, you may dropping the tank and seeing if a line is kinked, or you can pull your fuel filter and blow through it to see if its clogged. hope this helps.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 23, 2006
  • Feb 23, 2006
i have only seen a couple of those sensors go bad. and both of those was a focus not a mustang. is your car running ok?
F
FalconGuy016
437
Northern VA
Feb 24, 2006
  • Feb 24, 2006
I *think* it is running slower than usual, but it's nothing I can confirm. Would it be running noticably crappy, most likely?
Mike97gt
it doe snot
10,633
Feb 24, 2006
  • Feb 24, 2006
do you have access to a fuel presure guage?
F
FalconGuy016
437
Northern VA
Feb 24, 2006
  • Feb 24, 2006
I don't think so, at least, not in my immediate area. Should this be my focus?
Edit: Googling shows me it seems to be a pretty simple thing to make, given the guage itself isn't that expensive. What should my fuel pressure be?
Mike97gt
it doe snot
10,633
Feb 24, 2006
  • Feb 24, 2006
well the pressure varies depending on driving conditions. with the key on engine off it should be at 50 psi will probally idle somewhere in the mid 40's
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
