  • SN95 4.6L Mustang Tech
Threw a plug!!!!!
  • Thread starter Thread starter HercFE
  • Start date Start date Feb 22, 2006
  • 3
1 of 3 Next Last
H
HercFE
55
Sacramento
Feb 22, 2006
  • Feb 22, 2006
Well, I was driving home from work today and threw a plug for the #3 cylinder, I barely limped it into Ford and they said it definitely did, I will get the extended warranty every time I buy a car now. It's only costing me 50$!! I hope they replace both heads though, I'd hate for it to happen on the old head when my warranty runs out. I'm wondering if they would put some FRPP headers on for me since they have to pull old ones anyways, if the labors free, would they be worth the money?? Sounds like this plug thing happens often from what I've read on here, has Ford recognized this problem???
sgarlic
3,085
Feb 22, 2006
  • Feb 22, 2006
They issued a TSB that discourages anyone from trying to re-tap the factory heads, they recommend the entire head be replaced, although there are kits out there to re-tap.
Out of curiosity, had you messed with the plugs at all prior to this happening, or are they the stock ones?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 22, 2006
  • Feb 22, 2006
Yes, do you have the stock factory installed plugs???
H
HercFE
55
Sacramento
Feb 22, 2006
  • Feb 22, 2006
It had different plugs in, the service rep said it wasn't a plug problem, he said the thickness of the material where the plug threads in was the problem. He said Ford covers it either way. he also said the new heads were supposed to be better, but I don't know if thats true, I just hope they replace both of them. Should I get the aftermarket headers??
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 22, 2006
  • Feb 22, 2006
THey will not put headers on your car. It is warranty work, you are lucky to be gettin the heads.
There's no work like warranty work...
sgarlic
3,085
Feb 22, 2006
  • Feb 22, 2006
If you had the stock '02 heads on there, then you'll be getting the same ones.. just regular old PI heads. If they plan on doing some custom port/polish work or something, then yeah.. it'd be better.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 22, 2006
  • Feb 22, 2006
you will only get the head that the plug blew out of.
bet your glad you have that warrenty now.
V
V6&V8SHO
  • Feb 22, 2006
Do they make better heads aftermarket that resolves this issue?
Mike97gt
it doe snot
10,633
Feb 22, 2006
  • Feb 22, 2006
nope. somebody should. esp. for the lightings
sgarlic
3,085
Feb 22, 2006
#10
  • Feb 22, 2006
  • #10
No aftermarket heads for our cars yet.. just ported/polished versions of the stock ones.
the98stang
2,408
Clovis, CA
Feb 23, 2006
#11
  • Feb 23, 2006
  • #11
God all these spark plug blow outs are scaring me...I need to check the torque on mine!
san~man
O-G
A little grass shack on a big lava rock
Feb 23, 2006
#12
  • Feb 23, 2006
  • #12
"Supposedly" the 04 heads have more threads designed into them versus the 99-03 heads and those are the ones used to replace the stripped heads.
3,287
24
69
Broke
Feb 23, 2006
#13
  • Feb 23, 2006
  • #13
Actually its worth asking your dealer (but dont get the FRPP headers they are crap).
I had a head replaced and my dealer (awesome) was fine with removing the other head too, keeping the car for 2 weeks while I send out both heads to be ported, and then re-installing both heads. I think they want a couple of hundred bucks! AND MY WIFE DIDNT LET ME DO IT.
Mike97gt
it doe snot
10,633
Feb 23, 2006
#14
  • Feb 23, 2006
  • #14
007. i know the only way a dealer would install aftermarket parts during the install is if the customer wanted to pay cash to have the aftermarket parts put on.
shallowreef
illinois
Feb 23, 2006
#15
  • Feb 23, 2006
  • #15
maybe i missed it but exactly what causes a spark plug to blow? so i can prevent that from happening
H
HercFE
55
Sacramento
Feb 23, 2006
#16
  • Feb 23, 2006
  • #16
When I talked to the service rep he said the cause was the thickness of the metal where the plug threads into the head, apparently it's not very thick. I wasn't beating on the car when it happened, just cruising at 80 on the highway when the check engine light came on and the engine started missing or sorta backfiring, you could also smell fuel. I'm just happy I could limp it to the dealer!!
Mike97gt
it doe snot
10,633
Feb 23, 2006
#17
  • Feb 23, 2006
  • #17
the plugs loosen over time and when this happens the firing of the cyl and compression vibrate the plug untill it destorys all the thread on the head. after a the threads are gone it shoots out taking the coil with it.
every once in awile it's a good idea to tighten down your plugs.
VPStang
346
bHAM, alabama
Feb 23, 2006
#18
  • Feb 23, 2006
  • #18
is it true what the above poster said about the issue being resolved with 04 heads?
SilverBullet00
1,150
Wichita, KS
Feb 23, 2006
#19
  • Feb 23, 2006
  • #19
Mine are ALWAYS loosening, its getting extremely anoying, is there anything else I can do to keep them in place?
H
HercFE
55
Sacramento
Feb 23, 2006
#20
  • Feb 23, 2006
  • #20
When I found out some info on the new head(s) I will pass along. The service manager at my dealership is also the guy who runs our mustang so I'm sure I'll get a straight answer from him. This plug loosening thing shouldn't be happening, is it because the heads are aluminum?? I never run into this problem before when I was into the small block chevy's..
  • 3
1 of 3 Next Last
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
