throttle body & plenum {idle problems} help?
sounds to me like one of the hoses isnt plugged in all the way, theres 2 on the air tube, and 1 on the back side of the plenum. Theres a few other wires to plug back in as well, check em all.
Sounds like a common problem. It takes the computer about a week to figure it out. Reset your computer, and it might speed up the process.
Check the voltage on idle too. It should read 0.99 volts when the car is running. On my car it was the bottom 2 wires.
mnbf said:
Remove negtive cable press brake 3or 4 times and leave if off for 30 min and hook it back up
Pressing brake! I thought you only remove the negative wire and start it again. Btw should I leave the car ON after resting the computer for 15 min or no need of doing this? Thanks a lot buddy. :nice:
after you reset the computer go for a little drive and then just drive normal and after a few starts stops and what not the computer will adjust eveything .. give it a coupkle days of normal driveing
