throttle body worth it?
Also, your intake plenum opening is only 60mm, so unless you want to port the opening, it won't do you any good. Save the money, if you did port match the intake with the larger throttle body, you may net 1-2 rwhp (that is probably high) considering that your intake is still a major restriction.
