throttle body
  • Thread starter Thread starter legalize420
  • Start date Start date Jul 17, 2005
legalize420
1,541
South Florida
Jul 17, 2005
  • Jul 17, 2005
i put the stock tb back on the car and it runs so much better. no more hanging idle and the car is more comfertable to drive. i think it is safe to say the 70 is to big for what i have now. do you think i should stick with the stock tb until i get either heads or a poweradder. would it be worth it to go for the 65 with the stock heads. i will probally just sell the bbk and get some gears. what do you guys think?
sodaking663rd
47
annapolis, md
Jul 17, 2005
  • Jul 17, 2005
the 65mm is much more manageable. you may want to try adjusting the idle screw on the throttle body before ditching it...it may be set too low causing drivability problems.
sirr0bin
174
Winnipeg, Manitoba
Jul 17, 2005
  • Jul 17, 2005
you might wanna try drilling a small hole in the middle of the throttle body plate on your 70mm, it helps in a lot of cases. the stock one has that done as well
65mm will be fine on a stock engine
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
  • Mindseye007
  • Aug 16, 2026
Mindseye007
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
