  • 2005 - 2009 Specific Tech
Throttle Body
  • Thread starter Thread starter 07_Stanger_09
  • Start date Start date Apr 24, 2009
07_Stanger_09
15
B'Ville
Apr 24, 2009
  • Apr 24, 2009
I'm just wonderin' what size the factory throttle body is on the S-197. Thanks
SpartaPerformance
2,517
61
89
Long Island NY
Apr 24, 2009
  • Apr 24, 2009
Each bore is 55mm, I put on one from a gt-500 they are 62mm each. Thats was a nice mod.
'08GTcaRED
330
Victorville, CA
Apr 25, 2009
  • Apr 25, 2009
tommyroc, did it just fit right on or did you have to 'tweak' the mounting plate? I've been thinking of getting the 65mm GT500 throttle body for my GT...
SpartaPerformance
2,517
61
89
Long Island NY
Apr 25, 2009
  • Apr 25, 2009
It comes in a kit with an spacer plate from Metco and now even FRPP has a kit. I'm not too familiar with the FRPP kit as yet it's brand new but the Metco kit is great and it does fit most cold air kits. The GT500 TB is physically larger so CAI's with a rubber snout can be stretched over it (a bit of a pain) but hard rubber or metal tube kits may require the purchase of rubber flange and larger clamps. I personally have the Moto blue kit that I purchased from a website that has really horrible service but at the time none of my wholesalers had kits available.
'08GTcaRED
330
Victorville, CA
Apr 25, 2009
  • Apr 25, 2009
Really? Nice! I had asked BBK a while back if they were similiar or not, but if someone fabbed a plate to make them such then that's perfect Thanks a lot tommyroc, I appreciate you help!
KLO
28
  • Apr 26, 2009
GT Tb's have 55MM Bores like you said. GT500 TB's have 60MM bores. BBK upgrade for the GT has 62MM bores. BBK upgrade for the GT500 has 65MM bores.
FRPP does not make an adapter kit. They will sell you the GT500 TB and you can buy an adapter from somewhere else.
O
o0Dan0o
485
  • Apr 27, 2009
The man is correct. Also Techco ports the stock TB to 62mm, linky. I'll probably go that route, as it's the cheapest.
Dan
'08GTcaRED
330
Victorville, CA
Apr 27, 2009
  • Apr 27, 2009
Hmm good point Dan. Thanks for the link...I might just do that instead... I prob will need the 65mm later, but prob not at the moment or near future so a 62 will work fine
klaw
343
Calgary, Alberta, Canada
Apr 27, 2009
  • Apr 27, 2009
Anyone know what the flow values are for the various TB's (twin 55, 60, 62, 65)? I'm looking at the Whipple monoblade for the GT rated at 1750cfm for my new blown stroker setup.
O
o0Dan0o
485
#10
  • Apr 29, 2009
  • #10
Not really sure Klaw, other than to say the monoblades should outperform the twin bores by a wide margin (I'd guess ~30-50%). Though a 62mm twin bore should be fairly close, the monoblade should still be better (has 15% more surface area).
Dan
klaw
343
Apr 29, 2009
#11
  • Apr 29, 2009
  • #11
Dan
That was my thinking too. Can't say I'm really happy with Whipple though. They don't have any monoblades in polished and apparently aren't ordering more (nice that I paid extra for a polished blower). I ordered/paid for a black monoblade a couple weeks ago and it still hasn't shipped - they're waiting for their order which was supposed to be there two days after my order. Now my build is probably going to stall and I have dyno time booked etc.
The Ford Racing twin 62mm in polished looks like a very nice piece. I probably should have just ordered that.
blbrchnk
268
Bridgeport, WV
Apr 29, 2009
#12
  • Apr 29, 2009
  • #12
I didn't realize that upgrading the throttle bodies on these cars was actually a performance gain. I thought that I read early on that there wasn't much to be had there. How much difference does it make?
klaw
343
Apr 29, 2009
#13
  • Apr 29, 2009
  • #13
Probably not worth it for a stock setup but I'm upgrading everything - forged stroker shortblock, cnc heads, oversized valves, blower grind cams, lt headers, 10-rib blower drive, 16psi boost. I installed the Whipple HO last year.
mhanksii
336
Maryland
Apr 29, 2009
#14
  • Apr 29, 2009
  • #14
Not trying to hijack your thread but has anyone ordered this Techco TB yet? I want to know if it ships with the TB sensor and butterfly motor already on it or if it comes bear like the BBK TB. Also would I need a tune to run it on my F/I engine or will the computer adjust through the MAF?? Any help would be great and thanks in advance guys.
O
o0Dan0o
485
#15
  • Apr 29, 2009
  • #15
My guess is a tune will be required. I'd call them to see what the their TB comes with.
Dan
SpartaPerformance
2,517
61
89
Long Island NY
Apr 29, 2009
#16
  • Apr 29, 2009
  • #16
Well FRPP also has a twin 63.5mm bore TB kit that comes on the new Cobra Jet race car and one just came in 1st place in it's class with a qualifying time of 10.08 1/4 mile time so I would say a twin 63.5mm would be plenty for street use.
klaw
343
Apr 29, 2009
#17
  • Apr 29, 2009
  • #17
I believe that one is the GT500 version so would require an adapter plate for the GT.
M
Throttle body
  • miser143
  • Jul 13, 2026
CAMTWO1070
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
Help finding throttle body
  • jpmaxx
  • Apr 21, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 22, 2026
jpmaxx
G
Throttle body cleaning
  • Greg Smith
  • Jul 21, 2025
2005 - 2009 Specific Tech Aug 3, 2025
Greg Smith
G
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
