throttle gets stuck
rudy herrera
110
today when i started my car in the morning the car reved to 3k and stood there i turned it of cuz i was lit wtf then i started it again and did the same thing i floored it and it whent a little hyer then i turn it of and oppen the hood to see wat was going on i didt notice any thing so i needed to get to work so i unpluged the batery and started the car and everything was fine when i came out of work the same thing happen so when i got home i checked it all i notice was that in the fender well theres a plug were the vacum hoses conect for the brake buster in the plug there little plugs that says ac and othere thing well there one that says b/r i was wondering wat this is could this be causing my problem and if it is why
A vac leak can cause an issue. Do you see disconnected vacuum hoses (or uncapped nipples on the log)?
Have you pulled codes?
If everything looks decent, a tip from JRichker is that when a car gets a random high idle that's temporarily resolved when the car is turned off and restarted, the TPS can be at fault. Apply that info to your situation if it fits.
Be sure to include the year and mods for the best chance of finding the solution.
Good luck.
