throttle linkage
  • Thread starter Thread starter 19mustang65
  • Start date Start date Nov 12, 2004
19mustang65
201
Phoenix AZ
Nov 12, 2004
  • Nov 12, 2004
i put a new carb and intake on my car today and i had to rig up a throttle cable because the previous one wouldnt work at all. i had a holley on before and the linkage wasnt perfect..now i have a edelbrock and the linkage is really bad and ill like to fix it, considering my tranny kick down doesnt work the way i have it set up... sombody had told me theres a company that makes the linkages kits or something but he wasnt possitive...any suggestions?
ssppiitt
206
Mountain View, Ca.
Nov 13, 2004
  • Nov 13, 2004
Try Lokar.
66HertzClone
428
Central New Jersey
Nov 13, 2004
  • Nov 13, 2004
Try this kit, http://www.secureperformanceorder.c...yID=9&ClassID=139&SubclassID=651&ProductID=57
It includes a bushing for the arm on the carb. I connected mine to the original bellcrank arm, just removed the bushing there and then measured and cut it to the correct length. I dressed mine up a little, I used a piece of aluminum tubing that I polished to cover the rod.
19mustang65
201
Phoenix AZ
Nov 13, 2004
  • Nov 13, 2004
are most of these universal then i need to bent it or whatever to get it to the right position? by seeing the differences between the stock carb, holley then the edelbrock there is a big difference.
P
Paul619
83
  • Nov 13, 2004
i just went from a holley to a carter last night and i didnt have all that much of a problem getting it to work i just bent the kickdown lever so it would work now i am all set
66HertzClone
428
Central New Jersey
Nov 13, 2004
  • Nov 13, 2004
Insert the rod end connectors in the holes from opposite sides. Clear as mud right? I used this kit on my 66 which has a Demon carb. I installed the ends as I explained above and the rod has very little offset left to right when assembled.
351carlo
267
Philadelphia
Nov 13, 2004
  • Nov 13, 2004
Most retail type parts stores have universal throttle cables. I use one on my 70 and it works out just fine. It said fits most GM applications, but believe me it's right at home in my Stang. Cut the cable to fit and it's got the proper fittings to keep it nice and tight. I had the same problem when I went to my Edelbrock from my Holley. Now that I'm going to a Demon, I decided a new cable was in order.
Kickdown....who uses that? That's what a shift kit and a floor T-handle was made for.
Engine Mechanical Throttle Linkage
  • G Man
  • Jan 18, 2025
Fox 5.0 Mustang Tech Jan 18, 2025
G Man
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Resolved Carb: which throttle cable bracket? (SOLVED)
  • doctorj357
  • Dec 19, 2023
7K
Fox 5.0 Mustang Tech Jan 20, 2024
doctorj357
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
