Throttle Linkage
  • Thread starter Thread starter cptam1
  • Start date Start date Jan 29, 2006
C
cptam1
32
Ft Riley Ks
Jan 29, 2006
  • Jan 29, 2006
I bought a brand new 650 CFM Holley/Double Pumper, installed it put on the linkage nut and the the throttle linkage(cable) has so much play i have no pedal. NONE. how can you adjust the throttle cable length.
blk 02
57
Shreveport, La
Jan 29, 2006
  • Jan 29, 2006
Just shorten the rod that attaches the carb to the throttle pedal assembly.
N
nmk_61802
61
  • Jan 29, 2006
Alternative to making your existing rod work:
http://www.fordmuscle.com/archives/2004/08/ThrottleLinkage/index.php
65 fastback
1,347
Northern VA
Jan 31, 2006
  • Jan 31, 2006
Great link, thanks.
302 coupe
1,952
Macon, Ga.
Jan 31, 2006
  • Jan 31, 2006
did you people not read his post, He clearly states that he is using a cable, not a rod.
The cable should be held by a bracket that is bolted to the rear drivers side of the intake. The cable is clamped to the bracket with a little strip of sheetmetal and a sheetmetal screw. You can loosen the screw and slide the cable housing towards the rear, then retighten the screw to clamp it back in place. This should remove most of the slack, unless you have some missing parts or have something installed wrong.
If you need pic let me know. I always use cables instead of the rod linkage, they're just easier to work around.
Edbert
3,548
32
109
Austin TX
Jan 31, 2006
  • Jan 31, 2006
Went by Lowes and Home Depot today and they don't carry Heim joints. Anyone know of a source?
2nd Mustang
2,488
Southern California
Jan 31, 2006
  • Jan 31, 2006
I tried those stores. The workers at both stores didn't know what a heim joint was. I bought all the parts at a contractor's hardware supply store, less the heim joints as they were out of stock this week, and spent around $7 so far. The washers from the self tapping screws fit the Holley throttle hole perfectly.
N
nmk_61802
61
  • Feb 1, 2006
http://www.mcmaster.com/
search for "ball joints"
HistoricMustang
2,359
Confederate States of America
Feb 1, 2006
  • Feb 1, 2006
I made one of these for the race car (you certainly do not want to have throttle problems at high speed). It is identical to the pic in the link and works very well. Picked up the parts at Ace Hardware.
HistoricMustang
www.historicmustang.com
Edbert
3,548
32
109
Austin TX
Feb 1, 2006
#10
  • Feb 1, 2006
  • #10
I feel bad that we've (I've) completely hijacked this thread, so to answer the original question...
What you do it detatch the rod from the pedal-pivot at the rear. It is held in place with a cotter pin. Once it it loose you can turn it along the threaded part of the rod to shorten/lengthen the throw as appropriate.
Now back to the hijack
Thanks for the tip about McMasters, they have a WIDE selection of stuff. I'll try a local Ace Hardware first but I'm usually not able to find stuff there that the big-box stores don't have.
I was looking at these and thought this might be a good choice for the ends.
That way the rod that goes through the two shanks could be the exact size and not require the rubber bushings and I wont have to buy them from Moroso.
Opinions?
2nd Mustang
2,488
Southern California
Feb 1, 2006
#11
  • Feb 1, 2006
  • #11
I've found that Ace Hardware has stuff that the big box stores don't carry. The only draw back is that Ace Hardware is not near where I live or work.
302 coupe
1,952
Macon, Ga.
Feb 1, 2006
#12
  • Feb 1, 2006
  • #12
I guess you didn't notice the original poster is using a cable
Edbert
3,548
32
109
Austin TX
Feb 1, 2006
#13
  • Feb 1, 2006
  • #13
LOLOL...I tried...
Okay, I've adjusted the cable types before too, recently on my T/V cable. If it is too long you are in business, if it is too short you're screwed, so be careful. What I did was measure the cable housing twice, mark the desired length, remove tha casing from it's retainer, remove the cable from the casing and cut the it (the casing) at your mark, I used a cutting disc. The re-insert the casing into it's housing, re-insert the cable into the casing, snug everything up, adjust to taste and cut off the excess cable.
EDIT: I just saw you edited your post above too, guess we both misread his post, poor guy
302 coupe
1,952
Macon, Ga.
Feb 1, 2006
#14
  • Feb 1, 2006
  • #14
I only added in the last line about pics if he needs them.
wild70stang
317
#15
  • Feb 1, 2006
  • #15
I am wondering if this idea would work if you had an automatic tranny. I would just modify the throttle linkage and leave the tranny kickdown in its current place. Also, this idea can work for virtualy any carb, just as long as its length is fitted correctly?
C
cptam1
32
Ft Riley Ks
Feb 5, 2006
#16
  • Feb 5, 2006
  • #16
I m sorry i have not returned any postings. Im in the Army and have been busy. Yes yo are correct its a cable. I have tried to remove the cable from the casing. ( you have any pictures) Help. It wont un-screw. Im talking at the Carb end, or do yo mean the pedal end.
AOD TV linkage
  • Titanium90
  • Jun 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2025
KRUISR
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
Engine 86 GT heavy throttle pedal
  • 86 Convert
  • Sep 4, 2025
Fox 5.0 Mustang Tech Sep 4, 2025
86 Convert
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
