  • SN95 4.6L Mustang Tech
Throttle problem
  • Thread starter Thread starter 04DarkShadowGT
  • Start date Start date Aug 24, 2006
04DarkShadowGT
474
Fort Wayne, IN
Aug 24, 2006
  • Aug 24, 2006
I have a 98 GT that is having a weird issue. When I push on the accel it acts as if the cable is stuck on something for a little but then it frees up fine. You have to give it a little pressure to get it to break free and the all is well. It runs and accelerates fine other than that. It does it when moving and in neutral.
I am thinking the cable is sticking somewhere but any ideas or happened to any of you.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 24, 2006
  • Aug 24, 2006
Could the carpet or floormat be interfering with the accelerator pedal's travel?
04DarkShadowGT
474
Fort Wayne, IN
Aug 24, 2006
  • Aug 24, 2006
Could be, I will check it out.
Smeech
148
Fremont, Ca
Aug 24, 2006
  • Aug 24, 2006
run some TB/carb cleaner through the throttle body. My accufab has been sticking... it pisses me off, because you can't drive it smoothly. I notice you have an aftermarket TB (BBK) as well. The cleaner helps but sometimes after a few weeks it starts sticking again..
BooWFO
991
Louisville, KY
Aug 24, 2006
  • Aug 24, 2006
yeah check the carpet/floormats, also might wanna think about spraying a lil wd40 on cable and TB pivot points. Might also have the nasty carbon build up causing the blade on the tb to stick at some point in travel.
N
Sticky Throttle
  • NooStang
  • Jun 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
General karthief
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
