Throttlebody question
  • Thread starter Thread starter lgbnaf7
  • Start date Start date Aug 22, 2005
L
lgbnaf7
61
Tacoma Wa
Aug 22, 2005
  • Aug 22, 2005
I am in the process of changing my valve cover gaskets. I removed the upper intake and the job is halfway done. I am replacing the gasket in between the upper and lower intake the gasket in between the Throttle body and the ? What is the peice called in between the Throttle body and the upper intake? How do I get this part off to replace the gasket in between. In the kit I received 2 gaskets. A thin one and a thick one. Whick one goes in between the throttlebody and which one goes in between the intake and that peice. The engine I am dealing with is pretty beat. Everything I touch seems to be just collapsing to my touch. The car is a 89 gt vert.
vristang
4,933
101
124
Seattle
Aug 22, 2005
  • Aug 22, 2005
First, hello to the WA Stanger. I feel your Tacoma pain, I went to college there a few years back and will never forget that Tacoma Aroma.
I don't remember much about the stock gaskets. I have been using silicone for the last couple of years because 70mm gaskets are kinda tough to find.
The extra part you asked about is the EGR spacer. I have no idea what gasket goes where though. But I am curious, and I am sure someone here will be able to help.
Good Luck
jason
bsedwebt70-5.0
320
Charlottesville, VA
Aug 23, 2005
  • Aug 23, 2005
the thick gasket goes between the EGR spacer and the upper intake plenum and the thin one goes between the throttle body and EGR spacer -- you may want to lightly coat them with silicone sealer because coolant flows through there.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Aug 23, 2005
  • Aug 23, 2005
remove the four bolts holding the TB to the EGR spacer...they may seem fixed, but simply need to be pryed apart (be gentle though). The gaskets for the 70mm (also works for the 65mm TB can be had from most performance stores..mine were Edelbrock. Clean the matting surfaces well, and don't over torque the TB to EGR spacer nuts..see manual. Also note...DO NOT overtorque the upper to lower bolts..the will strip quite easily..I choose to only snug them, that being near or just under 10ft lbs...no problems ever with this method.
Turd Furgeson
9
New Jersey
Aug 23, 2005
  • Aug 23, 2005
Make sure you seal both seals really well. I had a very slight leak in my 88 years ago after I changed them, and coolant was getting into the motor causing it to run like crap!
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
AOD TV linkage
  • Titanium90
  • Jun 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2025
KRUISR
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
  • dan50
  • Jul 18, 2026
dan50
