Throw out bearing
  • Thread starter Thread starter PeteyAce
  • Start date Start date Dec 21, 2004
PeteyAce
346
Dec 21, 2004
  • Dec 21, 2004
My transmission started making a real loud rattling noise recently called my uncle mechanic and his said it soundnlike a bad throw out bearing, then he drive out and listeened to it and said that it was a bad throw out bearin, he said you have to take out the whole tranny to change it and i might as well just change the clutch, i just wanted to get an opinion on that, and what clutch i should get
jpctln
198
StL, MO
Dec 21, 2004
  • Dec 21, 2004
Which clutch you get depends on what kind of power you're pushing. What kind of plans? If you have a stock to mid-level modified 5.0 then I'd recommend a Valeo King Cobra. I have one and haven't had any problems with it. Some like Spec clutches as well. The kits come with a throwout bearing, clutch and pressure plate. Yes you do have to take out the exhaust, driveshaft, and transmission to access the clutch.
HISSIN50
34
129
Dec 21, 2004
  • Dec 21, 2004
often times with a TOB, it rattles with your foot off the clutch. if you ever-so-slightly press the clutch, it loads the bearing and the noise subsides.
having an uncle there who is a mechanic is better than us guessing from a keyboard.
i agree with the KC thoughts - i dont have one but am leaning towards it when the time comes. more info from you on your car, mods and intentions would help.
good luck.
BlackDrop50
217
Bay Area, CA
Dec 21, 2004
  • Dec 21, 2004
Definately a bad throwout bearing!
Yes you do have to take out the whole tranny. The throwout bearing goes on the tailshaft of the T5. Might as well change the clutch while you are at it. Get a King Cobra one for $160-180, lighter pedal pressure, more grip, it's a suitable, cheap, ford, quality clutch.
HISSIN50
34
129
Dec 21, 2004
  • Dec 21, 2004
i know what you meant, but for the sake of not confusing him, the TOB rides on the input shaft.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
