  • 1994 - 1995 Specific Tech
Throw-out Bearing
  • Thread starter Thread starter 95COBRA241
  • Start date Start date Oct 15, 2005
95COBRA241
339
Delray Beach, FL
Oct 15, 2005
  • Oct 15, 2005
My TOB has been whining for about 2months. I thought I'd change it when new motor is installed. Today the whine turned into a "chirping" sound. How long before it fails completely? Can I just replace TOB or does the whole clutch need replacing? What the best TOB? I've heard the stock one from Ford is best?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 15, 2005
  • Oct 15, 2005
I've always used whatever TOB came with my clutch, when I replaced it. I think they all end up chirping at some point, but I've never had one give me a constant whine. Mine's been chirping for somewhere around 25k miles, so I don't know if it's due for failure anytime soon. For a temporary fix, you could pop the cover off over the clutch fork, and carefully apply some grease to the friction points between the TOB and clutch fingers. Someone had the idea of using a spray grease for this recently, but that idea frightens me if I were to get some on the clutch disk.
HISSIN50
34
129
Oct 15, 2005
  • Oct 15, 2005
You might want to have a spare input bearing shaft retainer on hand in case you need it too.
Good luck.
95COBRA241
339
Delray Beach, FL
Oct 15, 2005
  • Oct 15, 2005
Thanks, I am just hoping to replace the bearing and not the entire clutch. I think '95's came stock with the steel retainer...so that should be fine.
BlownFiveLiter
18
108
Chicagoland
Oct 15, 2005
  • Oct 15, 2005
I'm not 100% positive, but I think I had to put a steel retainer on. Could've been on one of the 4 transmissions this car's had though...
HISSIN50
34
129
Oct 16, 2005
  • Oct 16, 2005
I dont think SN's came with steel retainers. Only snakes.....
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Oct 16, 2005
  • Oct 16, 2005
I say to pick up a steel retainer and a ford TOB.
95COBRA241
339
Delray Beach, FL
Oct 16, 2005
  • Oct 16, 2005
Yeah, I am gonna pick one up tommorrow and install it. When I start the car up there is a load screeching noise which stays at idle. As the car drives it disappears. When I depress the clutch I feel and hear a grind noise. I left the car in the garage and used the wife's Hummer to go to work today.
95COBRA241
339
Delray Beach, FL
Oct 18, 2005
  • Oct 18, 2005
I went to replace the TOB which was shot. When I removed the tranny any housing the TOB just fell out in pieces. The fingers on the diaphram were scored. I decided to replace entire clutch. I didn't realize that the stiff clutch pedal was from the worn diaphram, I thought it was from the cable that needed adjusting. Anyway after the install, no more chirping from TOB, and the pedal travel is smooth and easy.
FORCED2DV8
458
Grand Rapids MI
Oct 19, 2005
#10
  • Oct 19, 2005
  • #10
Make sure to put anti seize compound on the retainer, that will ensure nice movement for the life of your clutch, grease gets hot and eventually melts away.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
J&M Products Launches New Knuckle to Toe Link Bearing Kits for 2015+ Ford Mustang IRS
  • MRaburn
  • Mar 6, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Mar 6, 2026
MRaburn
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
