  • SN95 4.6L Mustang Tech
Throwing lean codes need help!!!
  • Thread starter Thread starter JerseyTrueBlue
  • Start date Start date Jun 10, 2009
J
JerseyTrueBlue
56
New Jersey
Jun 10, 2009
  • Jun 10, 2009
Im throwing codes p1000 system test incomplete, and p0171 and p0172 system too lean. My car is idleing horrible, missfiring and almost stalling I need help finding out how to fix this it's dangerously lean. My vacuum lines are all good as well as exhaust leaks and any other hoses. Car is a 2001 GT with a new crate motor swap (same 2v motor just brand new) I'm running my old ecu and just lately a predator tune to try and fix the problem which did nothing for me. Motor is not modified besides full exhaust it keeps getting worse and I can't afford to ruin my new motor if anyone has any tips it's greatly appreciated I'm running out of solutions
Crimson2v
  • Jun 10, 2009
Check for any intake leaks also, or possible MAF. You are getting unmetered air into the engine and that is where the codes are coming from.
squeak93
2,320
397
164
Joplin, Missouri
Jun 10, 2009
  • Jun 10, 2009
90% of the time the lean codes are unmetered air. Check and triple check things. May try a new maf as they can cause the issue (had an aftermarket C&L trip these exact codes on mine, new/used stock maf fixed it perfect). Check all connections again and then again. Did u buy the crate engine from intake down? If so its possible the lower intake gaskets didn't seal. Good luck and take your time. Don't drive it till you find the leak.
fast97gt
1,082
north carolina
Jun 10, 2009
  • Jun 10, 2009
check the silicone ducting tubes at the maf, if all is well then its possibly the maf. look also at the pcv lines and other LARGE lines. cracked intake, i wouldnt think so but also possible. i see you have a tb and upper plenum, check the gaskets there
joshjwc9
1,095
17
39
Palm Harbor, FL
Jun 10, 2009
  • Jun 10, 2009
If you cannot find any leaks in the intake side, try adding some fuel to your Diablo tune...
L
lang williams
567
cleveland, oh
Jun 10, 2009
  • Jun 10, 2009
i chased that problem recently an it was the maf. spraying around the intake didn't reveal a leak
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
