throwout bearing retainer
  • Thread starter Thread starter brammabull69
  • Start date Start date May 5, 2006
brammabull69
50
carbonado, wa
May 5, 2006
  • May 5, 2006
my throwout bearing retainer is all torn up and i was wondering where i can get a good one from because i bought one from summit racing and it ws wrong then i sent it back and they sent me a different one and it was wrong again so i am goin to get a refund and buy one somewhere else.
4G-KDMP
935
CA
May 5, 2006
  • May 5, 2006
im a newb and willing to learn all i can but what is throwout bearing retainer?
Fett
766
  • May 5, 2006
Were the ones you got from Summit a completly different design, or did they simply not fit over the output shaft and bearing? If that is the case, I would be willing to bet you have a 2.3l T5 in your car.
I ran into that when I bought my car, it had a T5 out of a 2.3. The retainers I bought wouldn't fit, so I measured the diameter of the output shaft and found out it was not the correct size for a 5.0. I went to the local boneyard and pulled a T5 from a GT...only to get it to the shop and find out that IT was also a T5 originally out of a 2.3. So there are 5.0 Mustangs out there with 2.3 T5s in them. The only difference is the pilot bearing, which you will need to replace if you get the correct T5.
In other words, you can either find a retainer from a 2.3 T5, or go get a T5 made for the 5.0 and a new pilot bearing.....IF that is the problem you have.
brammabull69
50
carbonado, wa
May 5, 2006
  • May 5, 2006
the shim and race were to big to go in the one i bought from summit i didnt even try to put it over the shaft because i tried to put the the race amd shim in it and it didnt work.
Fett
766
  • May 5, 2006
Yea, sounds like you have a tranny out of a 2.5 in it.
The problem is that nobody makes bearing retainers for that output shaft, so you have to find a used one....that was my delima. I would have kept the tranny, but I couldn't find a good retainer. I tried a new OEM retainer for a 5.0 T5, and I had the same problem. I ended up just buying a rebuilt WC T5.
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
  • Mindseye007
  • Aug 16, 2026
Mindseye007
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
