I JUST GOT MY 4.10;S INSTALLED LAST WEEK AND NOW UNDER NORMAL BREAKING I FEEL A THUD COMING FROM THE REAR END. DOES ANYBODY HAVE ANY IDEA WHAT THIS IS? IT'S AN AUTO BTW.
QDRHRSE said:Rear u joint not tight enough enough or wore out?[/QUO
I DON'T THINK THATS IT CAUSE NONE OF THIS WAS HAPPENING BEFORE THE GEARS WENT IN. I CALLED THE SHOP THAT DID THEM AND THEY SAID THAT THINGS LIKE THAT HAPPEN WHEN YOU GO TO A STEEPER GEAR BECAUSE EVERYTHING IS MOVING FASTER NOW AND ALL THE MOVING PARTS HAVE TO CATCH UP WITH EACH OTHER WHICH DOESN'T MAKE A LOT OF SENSE TO ME. I GUESS I GOTTA TAKE IT UP THERE AND HAVE THEM REDO IT. THANKS FOR THE HELP GUYS.
svttech76 said:does this thud happen when you let off the gas without the brake or when you first apply the brakes.
when exactly does the thud happen, info i am looking for is.
1. is there any thunk when you accelerate
2. when you slow down what MPH does the noise happen at? is it when the car comes to a halt, when brakes are first hit or what.
before we condem the rear end itself atleast give us a decent description of the noise. so far I see no reason to suspect the ring and pinion setup.
