  • SN95 4.6L Mustang Tech
Ticking header?
  • Thread starter Thread starter Fastroc
  • Start date Start date Sep 16, 2009
F
Fastroc
  • Sep 16, 2009
Have a 06 mustang installed BBK shorty header and bbk Xipipe with cats. Sound fine for about first 50 miles, and after that heard ticking noise. I am getting a ticking sound on the drivers side. Took it to ford they told me it was header number 6 cylinder where they where getting the most sound. As I increase RPM's ticks faster, the sound never gets softer as it warms up stay's the same from start. The exhaust guy said that new mustangs are know for the bolt's backing out is that true? I just was wondering if changing the blots to locking bolts may solve problem. Also is there a way to check if leaking or if gasket is bad.
Thanks
Frank
squeak93
2,345
416
164
Joplin, Missouri
Sep 16, 2009
  • Sep 16, 2009
If its already ticking, your likely going to have to change the whole gasket.
Use OEM ford gaskets not the crap ones u get when you buy headers. pushrod motors are much more notorious for bolts backing out. If you used anti seize on your threads when u put them back in, then they should of held just fine. I'd just bet u blew the gasket out.
joshjwc9
1,095
17
39
Palm Harbor, FL
Sep 17, 2009
  • Sep 17, 2009
Team Ford Parts Online- Ford OEM Parts at a discount
This may not be the right part, but give them a call and they can get you the right gaskets for cheaper than your local stealership.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
G
2001 Mustang GT noise after header and control arm (x2) install
  • gilmo5
  • Jan 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jan 12, 2025
weendoggy
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
J
Shorty header install making tick noise
  • Jose36500
  • Oct 22, 2023
2K
2005 - 2014 S-197 Mustang -General/Talk- Oct 30, 2023
Jose36500
J
