Ticking sound!?
Ticking from where ?
It could be a few things. What happened outside you noticed ticking ?
Remove the belt and fire it up. See if the tick goes away when the belt is off. That will narrow it down. If it is still there then its something in the engine. Or the tube that runs to the smog pump hoses and pipes aren't plugged.
If you took the pump off you may be hearing an exhaust leak. One pipe runs to the exhaust and the other runs to the back of the heads ( into the thermactor passages )
