  • SN95 4.6L Mustang Tech
Tie Rod Issue Please Help!!!
  • Thread starter Thread starter DTNODYA
  • Start date Start date Feb 17, 2006
First Prev 2 of 2
DTNODYA
831
#21
  • Jul 7, 2006
  • #21
Stangless,
Damn my car was gross when I posted that. Uhhhhhh....
Anyway, the part with the green arrows pointing to it is the actual "Tie Tod, AKA Inner Tie Rod" It goes into the boot and I'm pretty sure that a nut holds it in place but I don't really know for a fact. I didn't replace mine, I just replaced my "Tie Rod Ends", which are the pieces that are screwed onto the ends of the "tie rod/inner tie rod".
So, basically the steering rack has two inner tie rods coming out of it and tie rod ends screw onto the end of each inner tie rod (used to adjust toe for alignments)... Damn that sounds confusing if you read it fast.
Hope that helps some. I STILL don't know if inner tie rods go bad or what .... but now that my thread is alive again, maybe someone will enlighten us further.
BeCool
#22
  • Nov 12, 2006
  • #22
how do you get the inners out?
BlackenedSVT
1,841
New Jersey
Nov 12, 2006
#23
  • Nov 12, 2006
  • #23
rezzed from the dead huh?
DTNODYA
831
#24
  • Nov 12, 2006
  • #24
What up thread. :SNSign:
No idea how to get the inners out.
Hey, at least somebody is using the search button.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Nov 12, 2006
#25
  • Nov 12, 2006
  • #25
THis thread has lots of useful info. I just had my alignment done and my outer tie rod ends need to be replaced as well it seems. If i put my hands on the tire at the 3 and 9 o'clock positions, i can shake it back and forth. Might get new ball joints while i'm at it.
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Nov 12, 2006
#26
  • Nov 12, 2006
  • #26
If I can do that, I need to replace the outer tierods?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Nov 12, 2006
#27
  • Nov 12, 2006
  • #27
when you do this ( with the wheels off the ground) you will be able to move the wheels just like the car si turning, but if you feel looseness while you do that then you need either outer or inner tie rods and you need to feel around while moving the wheel firmly to feel where the play is.
First Prev 2 of 2
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
Foxbody adjust alignment
  • Creomod
  • Jun 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2025
2000xp8
