  • 1994 - 1995 Specific Tech
Tie-rods
  • Thread starter Thread starter diablostang
  • Start date Start date May 17, 2007
diablostang
425
Raleigh, NC
May 17, 2007
  • May 17, 2007
I took my Cobra to be aligned this afternoon, and the wheel sensors couldn't communicate with each other cause my driver outer tie-rod is bent real bad.. How hard are these to replace? Easy to do in driveway?
thanks!
D
dj_puppet_178
10
California
May 17, 2007
  • May 17, 2007
ill let you know tomorrow im replacing the tie rod ends and rack and pinion
C
CMEFLY
64
bonney lake WA.
May 17, 2007
  • May 17, 2007
did you hit a curb? if so hopefully thats all that bent. Outer tie rod is very easy to do. jack up your car and remove the wheel. Lossen the lock nut between the inner and outer tie rod. remove the cotter pin and nut on the outer tie rod. take a hammer and if you hit the knuckle on the side where the stud for the tie rod goes through it will come out. or get a pickle fork and place it between the tie rod and knuckle and hit the fork with a hammer it will come loose. Count the turns it takes to remove and reinstall new one the same amount, that will get you close enough to do alignment. i like to put a little anti sieze on threads of tie rod. hope that helps.
cjones
1,561
Avondale, AZ
May 17, 2007
  • May 17, 2007
they're real easy. just remember to count the turns it takes to get the old one off so you can put the new one with the same number of turns. then get it aligned.
diablostang
425
Raleigh, NC
May 17, 2007
  • May 17, 2007
Sweet, and what about the dust boot.. I kinda dimly remember some permenent clamps holding it on... How do you get those off/what to replace them with?
Thanks guys!
cjones
1,561
Avondale, AZ
May 17, 2007
  • May 17, 2007
sorry, it just occured to me you meant inner tierods (still recovering). those are more difficult but still doable. it's much easier if you get/rent an inner tierod socket (some may use pins instead of a nut). best bet is to read through the manual before you start to make sure you have what you need to do the job.
take care
1TallMF
955
Montreal
May 17, 2007
  • May 17, 2007
Its a surprisingly easy job. I actually changed my entire rack assembly and tie rods/ends last weekend in about 3 hours taking my time at it. should take you a couple hours if you don't have trouble unscrewing the inner tie rod from the rack. Hardest part was hammering-off the outers from the spindles since I didn't have that little puller tool thing, I have a pickle-fork but it did me no good.
BlackVert
5,589
9
98
Bethesda, MD
May 17, 2007
  • May 17, 2007
go ask the modular folks guys, you damn traitor!
seriously though, it is a complement to the guys on this forum that you come here for advice even though you no longer have a 94/95
diablostang
425
Raleigh, NC
May 18, 2007
  • May 18, 2007
Unfortunately, the modular guys don't seem to know much about tech.. I go to SVT-Performance and most people are busy discussing what rims and headlights will look best with their Mystic paint... hahaha They'd filet me with a butcher knife if I told them my car was originally mystic. (Mystic is $900 a quart if I recall correctly... way too rich for my blood)
But since these cars are the same body, I'd much rather ask you guys, since you/we actually work on our own stuff.
go-stang5.0
2,244
Glenview,Il
May 18, 2007
#10
  • May 18, 2007
  • #10
oh wow...it's orange now? I wouldent have the heart to do something like that. But I bet if I had a mystic I'd probably filet you with a knife too.
diablostang
425
Raleigh, NC
May 18, 2007
#11
  • May 18, 2007
  • #11
Nah, it's a coppery red now. I like the color. I wouldn't have guessed it was originally Mystic, except I have paperwork from the car when it was new. It's been completely color changed.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
C
Fox Tie Rod
  • Case
  • Oct 2, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 7, 2024
2000xp8
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
