The past few months I have been trying to figure out what the heck has been wrong with my motor. After doing numerous compression tests, I found that I can only muster 125 psi all around. I have tons of blow by and the power is just not there. I was told a way to determine your problem was to hook a air compressor into the cylinder, and listen for leaks, well i did have a leak and tons of the air came out of my breather. It is a Mexican 302, I would like the entire bottom end inspected, re ringed etc. How much am I looking at for block to be rebuilt and just the block with out any bolt ons installed. Soo basically I would send them my block with pistons, connecting rods and crank and get it back the same, I will remove and install the new cam. What size over bore should I go with? Should i get over sized pistons or get a sleeve? I was also considering, getting the block bored, and assembling it my self and have it balanced by a machine shop... but that is probably not very practical. thanks guys
Mike
also, I found a nice running c-4 outta 66 with a straight 200. Will that bolt up to my engine?
Mike
) works. Its not rocket science, just ned patience, a mentor, and some basic tools/hoist.
