Crank is still fine so I’m going with just pistons and rods and am torn between the CHP kit and the D.S.S. kit. Any opinions as to which I should choose, or other alternatives to the two?
Gearbanger 101 said:Guess I could have specified. Going witha positive displacement supercharger running probably 330-350rwhp. It's a pre-99 engine ('96 actually) with ported PI heads. I'll be shooting for the 18cc-22cc piston range to keep compression around 9:1 or so.
Yeah, the engine needs a rebuild. The previous owner ran it low on oil and ceased one of the camshafts in the head. Don’t know what kind of damage was done to it, but I’m not going to chance it. Besides that, I’m told that the stock rods are only good for about 400 or so flywheel horsepower, and I should be making somewhere between the 410-420 range, so I figured it was better safe than sorry. Lastly, I’ve heard horror stories of guys breaking a ring landing with as little as 2-3lb’s of boost and I plan on running no less than 9psi with this set up. It being fed by a positive displacement blower makes it that much more susceptible to failure…..not to mention the stock pistons with the PI heads will yield a 10.4:1 CR, which doesn’t mix very well with boost.nickthegenius said:So.....why build the bottom end for 330-350rwhp? Is the engine ready for a rebuild anyhow? Just curious because those are awfully low numbers to be worried about the bottom end.
It's an AED (Allen Engine Development) kit that utilizes an “S” ported Eaton M-90, not a twin screw. I may be able to squeeze a little more out of it with cams later on down the road, but 370rwhp is the most I’ve ever seen them make. I would like to have gone with a KB, but for one it's very pricey and is not a direct bolt, nor is it guaranteed that it would clear the hood line of my car. I'm Building a '96 Cougar XR7 BTW, not a Mustang.Jesus said:Which 9# kit only makes 330-350 HP at the wheels? All the numbers I have seen suggest (at least with a KB blower) youll see 380-400 HP at the wheels with 9#'s. The 6# kit makes like 350 HP at the wheels.
Not to mention the build quality of the Allen kit is by far the best I have ever seen (including KB and all of the other big names) and their customer support is apparently top notch.
Thanks boomshack, there's one viable alternative...any idea where they're located? (519) almost sounds like a Southern Ontario area code. I doubt I could get that lucky, though. Especially with an American flag in the upper left corner used in the banner.boomshack said:Check out this site as an alternative and an extra choice:
http://www.vtengines.com/46Ford.htm
Haven't used though, so just giving you another option
Gearbanger 101 said:Thanks boomshack, there's one viable alternative...any idea where they're located? (519) almost sounds like a Southern Ontario area code. I doubt I could get that lucky, though. Especially with an American flag in the upper left corner used in the banner.![]()
Is one kit any better, or any more complete than the other (CHP vs D.S.S.)
Huh, so it is an Ontario, Canada based company, huh....cause....if I'm not mistaken, there's an Ontario, California too, is there not? If it is Canadian, let's just hope their prices are too. $1395.00 is a damn good price for a forged rotating assembly!boomshack said:No problem. Looked it up online and it shows as Ontario...weird that they'd have a US flag on it, maybe an American company located in Canada.
Well...ya see. Here's the thing. I can't remember if the crank is good for 600rwhp, or 600fwhp? If it's 600rwhp, I'd say you've got nothing to worry about, but if not, I’d recommended getting a full forged rotating assembly. Either way, I don't see as to why you'd need to drop an extra grand or so on a race block. From what I remember, the blocks themselves aren't the real weak link, just the rods and pistons. With a good rotating assembly, I’d venture to say it should take somewhere around the 700rwhp mark.boomshack said:Hey so to expand on your comment about the block being able to handle 600 hp if the rods and pistons are upgraded, does that mean that if I plan on getting blown to 500rwp, I won't need a race block to go along with the forged internals? Thanks.
