What are good vehicles to get 9" rears out of? I want to end up with a disc rear and 31 spline axles.
I've read about the Lincoln Versailles rearend coming with disc brakes stock, but how does the width match up with the stock 68 rearend?
What about axles in later 69-73 mustangs? Would those work?
, but after looking into this idea for my project, I finally talked to the axle shop that would be doing the fitting of the 9" to my '68 as well as the drive shaft; this is what I found. Purchasing a unit from them, one that has already been built, was the least expensive way to go (for me- not qualified to do this level of cutting and welding like Hearne can). I was quoted $1200 for the entire rearend, w/ disc brakes, 31 spline axles and 3.50 gears. This was a posi center center section with new insides, new bearings, seals, etc.
