M mustang2k New Member Jul 31, 2005 25 0 0 Dec 7, 2005 #1 Dec 7, 2005 #1 With the diablosport tuner what advance degree should I go to for a saftey advance?
propellerhead New Member Apr 13, 2004 1,541 0 0 "but what's with the but shots?" Dec 7, 2005 #2 Dec 7, 2005 #2 It's covered here... http://forums.stangnet.com/showthread.php?t=535379
M mustang2k New Member Jul 31, 2005 25 0 0 Dec 7, 2005 #3 Dec 7, 2005 #3 So safely I can advance it to 10 or 15 or what?
propellerhead New Member Apr 13, 2004 1,541 0 0 "but what's with the but shots?" Dec 7, 2005 #4 Dec 7, 2005 #4 Yes, max it out. If it pings at WOT, back it off a little until it doesn't ping anymore. Remember, you are adjusting timing at WOT and it has nothing to do with timing at part throttle.
AdRock Member Nov 13, 2003 521 1 19 South Texas Dec 7, 2005 #5 Dec 7, 2005 #5 mustang2k said: So safely I can advance it to 10 or 15 or what? Click to expand... You can only advance by 10%, so you can't really get to 15.
[Twitch] Member Mar 30, 2005 168 0 16 Montreal Dec 7, 2005 #6 Dec 7, 2005 #6 Remember to use 93 Octane
propellerhead New Member Apr 13, 2004 1,541 0 0 "but what's with the but shots?" Dec 8, 2005 #7 Dec 8, 2005 #7 AdRock said: You can only advance by 10%, so you can't really get to 15. Click to expand... You can, in a round-a-bout way.
trailblazr81 Member May 17, 2003 571 0 16 Hollister, Cali Dec 8, 2005 #8 Dec 8, 2005 #8 Im at the full 10% and run crappy Cali. 91 octane with no probs.
jstreet0204 Active Member Jun 26, 2003 939 0 36 Winston Salem, NC Dec 8, 2005 #9 Dec 8, 2005 #9 AdRock said: You can only advance by 10%, so you can't really get to 15. Click to expand... It will go well beyond 15. 15 degrees on a t/a is merely base timing. Total timing should be more in the 25-30 degree range under WOT
03ghoststang Well-Known Member Jul 16, 2005 1,930 1 57 Los Angeles, California Dec 8, 2005 #10 Dec 8, 2005 #10 trailblazr81 said: Im at the full 10% and run crappy Cali. 91 octane with no probs. Click to expand... same here messed around with the timing alittle and running that Cali 91 octane
