Timing and cooling issues
markl89
12
Arizona
Guys,
Need some help. Have recently installed a new 331 into the 89. I have two issues, one is the initial timing and two the cooling issue.
The timing is the first one. Set the initial timing to 10 degrees when I first dropped the motor in. Car had no power and ran very hot. Very puzzeled at this point... I figured I would just start moving the timing up just to see what happened. Well to my surprise the power came back and the temp went down. I am currently at 32 degrees (with the spout out) with no detonation. Still runs much warmer than I would like.
Second issue, gets hot and won't cool down. Does not shoot up, but gradually...about 220 at the rad. The motor is new, water pump is new, thermostat is new, new 2 core aluminum rad. I have tried two different electric fans and the stocker with not much difference. Have jacked the front up to make sure the air is out of the system.
Mods: 331, aluminum heads, Comp 35-351-8, 75TB, BBK SSI intake, 70MM cobra mass air, 24lbr injectors, 9AL computer, 3" exhaust, 3:55 diff, 5spd, theoretical 9.7 comp based on heads and pistons.
No tuning yet.
Any help would be appreciated.
Mark
I suspected this as being the case. I am considering getting the Moats interface with the software and make the adjustments for the new meter and injectors. I have new 42lbr and a 90mm mass air that will be used with the Vortech after I get the motor broken in. The guy at the dyno shop told me that adding these now would be overkill and to simply adjust for the 24lbrs. I would appreciate your input on this course of action.
Curious though, why do I not have detonation while at 30+ degrees? Never seen such a deal.
Thanks
I seriously doubt that you are actually at 32* timing. New motor? Recheck timing chain and ensure it is installed and aligned correctly. Recheck initial timing and dizzy install. What balancer are you using... brand new? Properly keyed? Is the timing mark and bracket installed correctly?
Gear drive is installed correctly (took it back apart just to make sure I was not smoking something), Cam degreed correctly three times, Dist is correct. New Ford Balancer from a later 351 (best I can tell) with a 28once imbalance...when installed is key the same as the stock 302 with the marks in the same place. The timing pointer is from the stock 302.
Thanks
Ok... my last shot in the dark (unless I think of something else later... otherwise, I'm at a loss):
Find your old 50oz. balancer and temp install it and see if the timing marks align.
--also--
These may sound dumb...
Was the connector removed from the spout when you timed?
Is there any kind of chip in the EEC or any in-line device installed?
Overheating problem - make sure the plastic air dam below the radiator is in place and in good shape. It is mounted under the car and deflects airflow up into the radiator. It is easy to damage when you run over curbs or parking tombstones.
Finding TDC and installing a timing tape to degree the harmonic balancer.
TDC location process courtesy of Michael Yount
If you're trying to find ACTUAL tdc for cam installation/degreeing, follow the steps below:
Positive stop – obtain an old spark plug for the Ford engine – most of us have at least one laying around. Put it in your vice, and with a tool of destruction you deem appropriate – cut off the ground tip and bust up the ceramic around the center electrode. Keep pounding to get the ceramic and center electrode removed so you’ve got a good ¾” or so of hollow space inside what used to be the ‘business’ end of the spark plug. If you happen to break the ceramic on the other end of the spark plug, don’t worry about it. Once you’ve got a nice hollow space in the tip of the plug, take a 5/16” tap, and cut threads inside that end of the plug. I found that diameter to go right in without any drilling required. Once you’ve cut threads, screw in a 5/16" bolt about 1.5” to 2” long. Then take your hack saw and cut the head off the bolt. Wouldn’t hurt to take your file/grinder and dress up the freshly cut surface so no sharp edges or shrapnel enter the combustion chamber. Also clean up the threads on the plug so that it easily screws into and out of the plug hole.
Determining TDC – remove the passenger side valve cover. Rotate the engine (socket on crank bolt) until the #1 piston is down the cylinder on the intake stroke. Unscrew the spark plug in that cylinder, and replace it with the positive stop you just made. Only screw the positive stop in hand tight. Install your cam degree wheel and pointer (no easy task in some cases as harmonic balancer and other accessories will have to be removed). You may want to remove all spark plugs at this point because it will make it easier to smoothly turn the engine over in small increments. GENTLY rotate the engine clockwise until the piston comes to rest against the stop. Note the degree wheel reading. GENTLY rotate the engine in the opposite direction until the piston comes to rest against the stop. Note the degree wheel reading. TDC is exactly half way between these readings. Calculate where that position is on the degree wheel, remove the piston stop from the cylinder, and rotate the engine to TDC as you calculated it.
Alternate plan – no degree wheel needed, don’t need to remove the harmonic balancer. Use a timing tape available from Summit Racing.
Summit Racing SUM-163594 - Summit Racing® Timing Tape - Overview - SummitRacing.com - $3.95 Ford 302 & 351 timing tape, Summit brand.
Mr. Gasket 1594 - Mr. Gasket Timing Tape - Overview - SummitRacing.com - $7.95 Ford 302 & 351 timing tape, Mr. Gasket brand.
To install the timing tape and get it at TDC, do the following.
Clean the harmonic balancer with acetone, brake parks cleaner or whatever fast evaporating cleaner you have handy. You will need some small bottles of hobby or touch up paint to mark the balancer. I recommend red, white and blue.
Follow the instructions in the above tech note and find the first stop position. Make a visible blue mark on the harmonic balancer where it lines up with the timing pointer.
When you contact the second stop, make a visible red mark on the harmonic balancer where it lines up with the timing pointer..
Use a pair of machinist dividers to find the exact middle between the two marks. If you don’t have access to a machinist divider, use a compass that is used to draw circles. You can get one in the school supplies section of the supermarket. Use it to find the exact middle point between the red mark and the blue mark. Once you have found the exact center point, paint a white mark on it. That’s exact TDC: no guessing, no wondering, you are there.
Unwind the timing tape and peel the first bit of the backing off closest to the TDC or 0 degree point. Line up the TDC or 0 degree point on the tape with the white mark you painted on the harmonic balancer. Stick it the balancer and work your way around. A little super glue may be handy to keep the tape stuck on, but don’t get the timing tape stuck to your fingers. When you are sure that the tape is stuck on good, and whatever glue you may have used has set, then start the car and time the engine.
I will give the old balencer a try, worth double checking at this point. Spout was out.
As far a degreeing, everything checks out, TDC and Cam install, Used a Comp Cams kit, went back thru it three times.
Been around a lot of Mustangs and a lot of 302's and never have seen something so goofy. Is there any other way to tell what the timing is besides looking at the balancer?
Really appreciate every ones input, thanks for the time.
Time to try the timing tape installation tech note I posted... You'll find TDC and the 10-14 degree BTC point for timing and know it is correct.
I used the mother thumpr cam from comp cams, hydraulic flat tappet. I lined it up dot to dot on the timing chain.
Set the timing multiple times, but still gets hot very quick and stays hot. I advanced the timing and no matter how far advanced I go, it still runs good.
I know its a timing issue, plugs are great color, all the cooling system components are brand new.
I also bought a new harmonic balancer, but it is hard to read, so I am really considering the timing tape method. I think its worth a shot.
Update: went thru the steps with the piston stop and locating center, dead on "0" degrees to the balancer. Hope it was off but it was not.
Not sure if it makes a difference or not, but I was told by Comp Cams that this cam is advanced by 4 degrees out of the box...what will this do besides moving the power from the low to high end I'm not sure.
At a loss, could just be the computer not tuned to this combo
