Timing and nitrous
  • Thread starter Thread starter 98gtmustang64
  • Start date Start date Apr 30, 2010
9
98gtmustang64
57
  • Apr 30, 2010
do i have to pull any timing with a 100 shot
Tim2002GT
635
Tulsa, Oklahoma
Apr 30, 2010
  • Apr 30, 2010
If your using the stock tune, you should be ok without retarding timing. I recommend using 93 octane gas though.
9
98gtmustang64
57
  • Apr 30, 2010
ive got 92 in it now thats the highest i can find
BurningRubber
1,865
24
58
Apr 30, 2010
  • Apr 30, 2010
What would be your method of pulling timing?
I'd pull between 2-4* to be safe with 92 octane (even though it's only a point off), but you would probably be fine without doing so.
You do need 1 step (or 2, but 1 will work on a 100 shot) colder plugs. And I'd use copper plugs. I can't remember if it's platinum or iridium, but one of them has a negative chemical reaction with nitrous.
kuwait
194
Apr 30, 2010
  • Apr 30, 2010
leave the timing alone and 1-2 range colder triple check its copper plug and you should be good to go , 100 is a small shot
Red35th
609
Houston, TX
Apr 30, 2010
  • Apr 30, 2010
Most people will say you don't need to lower timing at all on a 100. I pulled 2* global from mine though. If you have an easy way to lower timing, I'd rather lose 10hp than be sorry.
9
98gtmustang64
57
  • Apr 30, 2010
im running ngk tr 55s
sweet tooth
154
  • Apr 30, 2010
i agree when i ran 100 shot i pulled 3 to 5 out in my 2000 to 4000 rpm range and i run ngk tr6.
I
Removing NX NOS kit?
  • ironhorsewayne
  • Jun 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 8, 2026
squeak93
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
M
Kind of a unique problem
  • MadMatt7
  • Oct 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2026
rednotch
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
