Timing chain issues
  • Thread starter Thread starter pwcracer
  • Start date Start date Aug 10, 2007
pwcracer
347
Hastings, MN, USA
Aug 10, 2007
  • Aug 10, 2007
Because of my lack of planning I attempted to re-use my old timing chain and gears from my destroyed 302. I lined up everything and installed the chain and the gears. When I turned the engine over by hand, I noticed the chain would go from very tight, to very loose, on both sides... My old cam was reground at delta cam, so if that was messed up they would have told me. The 306 block I am working on is new, so the only explanation is that the gear is warped.. No idea how that could happen... I am going to order a new timing chain set.. It just sucks this happens on a Friday when I had all weekend to work on the engine..
91 HATCH
Banned
May 17, 2007
262
illinois
Aug 11, 2007
  • Aug 11, 2007
are you sure the cam gear is setting straight on the cam
also the crank gear might not be on straight
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Aug 11, 2007
  • Aug 11, 2007
Yeah, it is always a good idea to replace the timing chain and gears...
Now, are you sure the tightness isn't coming from you rotating the engine over initially and then getting slack when you stop...(maybe the cam is spinning a bit quicker than the crank)...a kind of obscure thought...but...
ShortThrow50
923
Pa
Aug 11, 2007
  • Aug 11, 2007
For the very inexpensive price of a timing chain, you should ALWAYS replace it when givin the chance. Dont take short cuts
Black1987Stang
1,422
Jersey Shore
Aug 12, 2007
  • Aug 12, 2007
I just replaced my gear drive with a timing chain yesterday, if you need any pics of anything setup or whatever let me know. BTW I bought a Ford Racing timing chain set and it came with a new cam thrust plate too which is cool.
O
Timing guide
  • oilleak1000
  • Oct 10, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 10, 2026
oilleak1000
O
A
Engine 04 GT timing chain issue
  • AwesomeX1103
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 5, 2025
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Timing chain tensioner? (youtube video link)
  • slxne5.0
  • Sep 7, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 7, 2025
slxne5.0
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
