Timing cover gasket
DarkProphet
391
Quakertown, PA
Summit lists two possible part numbers for the timing cover gasket. Which should I use?
They also offer a kit with waterpump gaskets too, but I have a new waterpump with gaskets, so i would like to avoid them.
Ive found part numbers:
MRG-792G
FPP-2331
The FPP-2331 says it fits aftermarket SVO blocks only. Im using the stock 302 bottom end.
Thanks alot guys!
MysticKeith50 said:
FEL-TCS45449 ...17.99 for the timing cover/waterpumps. Sorry for the delay.:nice:
Ditto. That's the only kit I can find at autozone/checker/etc that has the correct water pump gasket for our cars. It has the right timing cover gasket & front main seal too.
Scott
