  • 1994 - 1995 Specific Tech
Timing For Dumbies
  • Thread starter Thread starter longfellowdeeds
  • Start date Start date Aug 12, 2004
L
longfellowdeeds
44
Lethbridge, Alberta
Aug 12, 2004
  • Aug 12, 2004
i am lost... could anyone give me some specific directions on how to set timing~!?? i got a timing light i know where the spout is and i just don't know how to tell what degree your at and how to change it!??? please help!!
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Aug 12, 2004
  • Aug 12, 2004
unplug the spout, hook up the timing light to the number 1 cylinder at the cap, losen the distributer hold down bolt. probably a good i idea to clean up the marks on the damper so its easy to read, start the car, point the light at the damper, base timings is 10 btc (check your manual just to be sure) turn the distibuter so it reads around 12 btc or so.. basically advance it till you hear pinging (if you don't know what that sounds like i'd stick it around 12 btc, just to be safe) thats what mines at. if you cant figure it out, get some one who knows how to do it.... you can **** up an engine with improper timing. hope this helps
H
HazMat404
1,749
Aug 12, 2004
  • Aug 12, 2004
yeah...i can get my car up to about 16* of timing on 87 octane. some peopel have to put 93 to make their car at 10* not ping. every car is different. on the dampner, mark the 10* with a short line and the 14* with a bigger line (use white out and try to be percise). if you want to do 12* then just put the line there too. your choice
maypo59
194
Central Kentucky
Aug 13, 2004
  • Aug 13, 2004
I just put a little chalk on the marks, then wipe the excess off.. works great. There is a bolt holding a flat clamp where the dizzy shaft goes into the top of the block, you loosen it. You will need a dizzy wrench, or at least I did, you have to set the timing with the engine at operating temp, and the offset wrench makes it a little eaiser on the hands.. then start the car, aim the light down at the timing pointer on the balencer, and turn the dizzy to change timing. If you have a multi spark ignition, its a good idea to put it in diagnostic mode first.. after setting it, tighten down bolt good, double check you didn't change it, then, put spout back in and reset ignition box as needed, button it up and see how it sounds/feels.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
CAMTWO1070
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
