timing & fuel ?s
rockingchair69
23
hey I was wondering if someone might be able to explain to me what running rich and lean was I just can seem to find anything that explains it in detail. I was also wondering what role timing had in all of this like if having it advanced/retarded to far could contribute and if it matters what octane you run with a certain amount of timing?
There's not much detail to rich and lean as far as definitions go. Rich basically means the air/fuel ratio has too much fuel. Lean means the a/f ratio does not have enough fuel.
If you search on "detonation" and "ping" you will find plenty of info on what advancing and retarding the timing will do...
G'luck
yeah like he said....rich is too much and robs power, lean is too little fuel and can cause damage.....so if anything...run it phat.
advancing timing does have a big role in it....you will make more power, but if your lean, you risk a bigger problem
you actually want to run as lean as safely can be.
but i like to be safer, and purposefully run phat. on nitrous you can melt a piston if you go too lean, usually just lose the plug electrode...but i run it phat to be safe
N/a if your running 14* timing make sure you have premium...if iy's cool out, and you have it at 12* your fine.
outside heat makes a big difference too, cuz the hotter the air is, the thinner it is.
humidity has a factor as well.
