Timing gear rubbing Camshaft thrust plate
  • Thread starter Thread starter sj9ers
  • Start date Start date Sep 21, 2009
sj9ers
71
  • Sep 21, 2009
I have an 87 mustang with a 302 and took out the engine to clean it up and repaint it. Well when I did I lost the camshaft thrust plate and bought a new one to put in. When I put the engine back in the car and started it you could hear the timing gear rubbing against the plate so I took off the timing cover and timing gear to replace the camshaft thrust plate with one I got from the junkyard thinking I had bought the wrong one. When I pulled it out you could see the deep wear marks from where the timing gear was rubbing on the new thrust plate. When I compared it to the one from the junkyard that I pulled from another 87 mustang they were exactly the same except the one from the junkyard had no wear marks on it. I was wondering if there is a spacer or something I am missing between the timing gear and camshaft and if the timing gear is even suppose to touch the thrust plate?
Thanks
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 21, 2009
  • Sep 21, 2009
what timing set you using?
sj9ers
71
  • Sep 21, 2009
the stock one that came with the car
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Sep 21, 2009
  • Sep 21, 2009
thrust plate too thick or gear on backwards?
sj9ers
71
  • Sep 22, 2009
i dont think so. I have everything setup just like in the picture. Maybe I'll just install the junkyard one and see what happens. I just don't want to have to change the plate again if it rubs and was just making sure.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 22, 2009
  • Sep 22, 2009
Is it rubbing on the Thrust plate bolts or around the inner radius of the thrust plate?
Mustang78
486
Aberdeen, WA
Sep 22, 2009
  • Sep 22, 2009
i had to grind a little on the ears of my thrust plate to fit the timing set.. i think it was made by cloyes
sj9ers
71
  • Sep 22, 2009
it's on the inner radius. I saw the marks on the junkyard one and it looks like it's suppose to be touching there but mine has a deep groove already cut into it from the rubbing.
1991notchbackLX
1,483
47
48
New York
Sep 23, 2009
  • Sep 23, 2009
Are you sure it's a stock piece? an engine from the junkyard could have had an aftermarket timing set on it already. If it's afterrmarket, comp cams (and some other companies) use a torrington bearing between the camshaft thrust plate surface and the rear of the gear. Make sure that you have a stock piece, and if you don't, be sure that bearing wasn't misplaced.
If you're sure it's a stock piece, make sure the the thrust plate and gear are on correctly. (There's an oiling groove on the BACK of the thrust plate.) Check camshaft endplay as well to be sure.
Here's a picture of a torrington style thrust bearing to help you visualize it:
W
wes 1977
23
#10
  • Sep 23, 2009
  • #10
sOME TIMES YOU HAVE COUNTER SINK TRUST PLATE BOLTS
W
wes 1977
23
#11
  • Sep 23, 2009
  • #11
R you sure you have the right bolts looks differnt than my old stock 1
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
#12
  • Sep 23, 2009
  • #12
Posted via Mobile Device
Its not hitting the bolts.
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Nov 17, 2026
AeroCoupe
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
