Timing & HP?
  • Thread starter Thread starter mustang6tee8
  • Start date Start date Aug 6, 2006
mustang6tee8
375
College Station, TX
Aug 6, 2006
  • Aug 6, 2006
I bumped up my timing to 14* and am wondering what hp/torque results it would give a stock 5.0. I wouldn't expect more than a few, but I'd still like to know an exact number. thanks
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Aug 6, 2006
  • Aug 6, 2006
maby 5-8 topps I would think
Killer50stang
632
  • Aug 6, 2006
14 seems too high. What kind of setup are you running? Make sure the engine doesn't ping. Usually between 10-12 is good unless you're running locked timing.
Jason
HISSIN50
34
129
Aug 6, 2006
  • Aug 6, 2006
If running locked timing, it's set close to 30*.
14* advance is quite common - no two engines react the same to a timing change and they all handle varying amounts of advance before audible detonation occurs.
There is a point before audible detonation where power falls off - just something to remember (and a reason to not run on the ragged edge of pinging).
Good luck.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Aug 7, 2006
  • Aug 7, 2006
I have mine set at 13* with spout out and I run 91 octane with good results....I can run 87 octane fine but under load in the higher rpm's I will get some pinging
mustang6tee8
375
College Station, TX
Aug 8, 2006
  • Aug 8, 2006
I can run 87 and it won't ping. The motor only has 86xxx miles on it
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Aug 8, 2006
  • Aug 8, 2006
I have my timing at 14 and run mid grade fuel. I have no pinging.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Aug 8, 2006
  • Aug 8, 2006
I run 18 degrees of timing and 89 octane with zero pinging. Tried 20 but made less power as Hissin described! The only way to get a number from bumping the timing is to be at a track or dyno, everything else is just a guess!
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • brandyn200
  • Jun 20, 2026
AeroCoupe
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
