Timing issue, initial versus total timing
  • Thread starter Thread starter 86sebring
  • Start date Start date May 27, 2005
86sebring
22
  • May 27, 2005
How do I set the timing on my car? '68 302, 268h cam, holley heads, performer 289 manifold, edelbrock carb, stock distributor, single points and vacuum advance.
First I set timing at 12° at idle, vaccuum removed. Then I tried 12° at 1500 RPM which is quit a bit different, but slightly less throttle response
What would be the right total timing as opposed to initial timing?
At what RPM should I set it at what degree?
thanks
LMan
1,246
Mom's basement
May 27, 2005
  • May 27, 2005
try total at ~36 degrees, 12 degress inital sounds ok
HistoricMustang
2,359
Confederate States of America
May 28, 2005
  • May 28, 2005
thanks
This may help!
http://www.badasscars.com/techtips.html#Anchor15
HistoricMustang
www.historicmustang.com
86sebring
22
  • May 28, 2005
At what RPM should it be 36°total ? And would that be with or without the vacuum attached?
thanks
R
ravenblack67
46
  • May 28, 2005
Per the shop manual for a '67 the intial timing is 12 with vacuum plugged. Timing at 2000 RPM should be 12-15 with vacuum plugged. Adjust here is replacemnent of springs. With vacuum applied at 2000 RPM, timing should be 34 to 37. I set mine for 36 by adjusting the 3/32" allen screw inside the vacuum advance nipple. 36 degrees is 2" from TDC on a 289/302. You can also get a timing tape from an auto parts store.
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
R
1974 Datsun 620 pickup / 5.0L HO
  • RJH46
  • Aug 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 24, 2025
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
