Hi there!
Well i might like to share a little issue i have currently with the tweecer , i am not having any issue controling timing on the WOT, logs show timing as i want, but at idle the timing does not match the spark_base_table , f.e. if i put something like 20, the timing on the corresponding load vs rpm , the timing its jumping to 30-37, however if i limit the timing on the borderline f.e. 20 the timing will be reduced to 15-17 , i am a little bit confused why on open loop and wot timing is well controlled and on idle ( closed loop) ? is not in control de base table. any one with similar problems , also i would like to know what timing are u using on the idle.
Thanks in advance.
On another off topic stuff i am now doing the AFR wot programming ( safely done at 22 degrees spark thanks grady for the safety ) and i could not beleive the richness of the maf transfer 7.0:1 at wot!! i have succesfully lowered to 9.5-10:1 but the problem i am facing is that the wot part of the curve is getting low and its now a step transfer and not a curve as for the word. the idle cruising part of the maf curve is good and the karmfs are showing nice 1.02-.998 tops , but the wot is getting alittle bit hard to make it a real "curve" , i lowered a little the fuel pressure and i will be tuning again as soon as i get a little time.
Edit:
Grady i was looking at your low slope and high slope values , since u are using the same injectors as i do, you are using this as a leaning feature or what is the purpose of having 2lbs higher slopes ??
Other thing , now that i leaned the mixture using the maf transfer now my top CFM according the maf readings is top 560 cfm as oposed of 750 that i was having before ( obviously due the lowering changes ) , does this looks right for a H/C/I or i am wrong.
Re-edit:
Sorry grady not trying to question your tune , but more as a questions ive seen some scalars that brings my attention.
PIP Filter : 20 ( what use apart from a rev limiter is this scalar for real use , does it interacts someway in the injector timing table ) since i havent touched the pip filter i am curious about this.
Fuel shut off deceleration minimum ect : 254 ( i am sure you used this as a cure to the horrible leaning the tune suffers letting the gas pedal of under the 20 mph or less deceleration and meeting the other criteria on the scalars) i also used this same value so i know what the use is for.
Manifold_volume : 3 ( stock is 5 , i readed your page and you are sure this cures a sudden lean on letting the gas off , but i have tried this and i kinda feel a little less trottle response, but i havent seen the lean spike yet.)
stabilized_min_ect : 140 ( i kinda understand this is the min. ECT temp the eec wil go closed loop ?? ) why did you lowered to 140 instead the stock 160 ??
Fuel OL multiplier time delay : 0 ( by name i kinda understand what this does , but do you have any comment why you eliminated the delay?? , since i dont see any OL multiplier beeing used on this eec.)
max_spark_retard : 21 ( whats the real use of this??)
open loop time delay hyst : .5 ( i kinda also understand by name the use of this but what was your experience lowering the delay on the switch to OL , did you see any leaning??)
Spark retard for knock sensor : 21 ( any success with this on the spark table , because i dont think this is too usefull since we dont use knock sensor ?? )
Sincerely this looks like a little agressive ( kinda questioning ) why you did this changes re-edit , but contrary to what it looks like i am questioning this because i want to know the experience on this changes and learn more things that are hardly documented on this strategy
Thanks grady in advance and sorry if this looks aggresive but its more like a exchange of why and what where your experiences on this changes that i see on your tune
Thanks in advance.
Edit:
Re-edit:
