timing mark and pointer missing
gideup
114
fort myers, fl
Wanted to check the timing on my 68 289 today. Hooked up a timing light and much to my surprise the timing pointer is missing. The timing marks are so worn on the pulley that all I can see is a cut line in the side of the pulley. :(
looking for a plan B on this. Replace the crank pulley?? Where do I get the pointer from? How does the pointer mount to the water pump or if not the pump then what? :shrug:
I guess the use of the word pulley was a bad choice. I did mean the harmonic balancer.
I cleaned off the face of the cover below the pump and don't see any marks other than the cast metal fins that stiffen the casting. The balancer has a hub between the block and the larger diameter portion. Are the marks on the hub or the portion out in front of the hub?
The marks are stamped into the larger diameter portion , usually have to hunt for them, by cleaning the rust and/or paint off. The timing pointer is just below the water pump, and about at the 1-2 O'clock position just above the crank. It's about a 1/4" protrusion about 3/4 inch long. You do have a passenger side inlet waterpump don't you?
Of course you have the same issues with the timing light, it is also set at idle. Where your timing is at any given RPM is based on your centrifugal or vacuum advance anyhow and is not where/what you time the engine to at idle.
What I usually do is adjust for maximum vacuum at idle and then back of about 0.5-0.75 inch or so, that makes it about perfect for the meat of the RPM range. Asuming your distro is curved right it should be fine for anything below 6,000 RPMs or so. Beyond 6K you are not using stock timing marks and components anyhow :D
