Timing Problem
  • Thread starter Thread starter 5.0ttops87
  • Start date Start date Mar 23, 2017
5.0ttops87
110
Mar 23, 2017
  • Mar 23, 2017
Would a bad pickup allow the car to run but not allow a timing light to work properly? I have a timing light that works fine on my grand prix (97 se 3.8l) ... i hooked it up to the car to test the timing light and it worked no problem. But my fox wont show a time no matter what i do(or rpm)... and its running rich as hell (fowling plugs).. just curious what you guys think.
D
Dart68
87
22
18
Mar 23, 2017
  • Mar 23, 2017
Is the light just not flashing or is it that you can't see the timing marks? The timing light uses the current passing to the spark plug to trigger the flash. If the engine is running and the timing light is hooked up right, it will flash unless there is no current to that plug.
5.0ttops87
110
Mar 23, 2017
  • Mar 23, 2017
Sorry- can't see any flashing.. i hooked it up to a couple different wires and seen nothing... I am confused on how its running if no spark passing lol it does sound quite a bit more rough at idle. But car is deffinitely running rich
D
Dart68
87
22
18
Mar 23, 2017
  • Mar 23, 2017
If it works on the other car and you immediately try it on this car and you're not getting a flash I would have to conclude that some how you're not hooking it up correctly on this car. I can't see any other reason it wouldn't work.
Anyone else have any ideas?
Mustang5L5
Mod Dude
Feb 18, 2001
43,348
18,083
224
Massachusetts
Mar 23, 2017
  • Mar 23, 2017
What brand wires are you running? Maybe the timing light clamp isn't seeing the voltage?
Put the clamp on the coil wire. Should be constant on
D
Dart68
87
22
18
Mar 23, 2017
  • Mar 23, 2017
That thought ran through my mind as well but I've seen super insulated racing wires cause a timing light to trigger.
If the light trigger is the clamp on type, check for a directional arrow and if one exists make sure that the arrow points towards the spark plug. Also, make sure the clamp closes completely.
5.0ttops87
110
Apr 1, 2017
  • Apr 1, 2017
Okay I'll give this a shot along with coil if that makes no difference thanks for suggestions.
5.0ttops87
110
Apr 1, 2017
  • Apr 1, 2017
I used the coil wire and it was flashing constantly and i guess the 5-8 (driver side plugs) all show a spark enough for the light but the passenger side plugs (1-4) do not show ... no matter what way i hook the light up I get nothing out of it..? Really freaking weird.. any other suggestions? I know the thing is running pig rich.. sure as hell smells like it (I put new lifters in and was considering the rockers might have gotten too tight when i torqued them down.. but I wouldn't imagine it'd play a role in the spark.. and engine turns fine..
General karthief
Mod Dude
Aug 25, 2016
28,112
10,729
213
polk county florida
Apr 1, 2017
  • Apr 1, 2017
Switch a plug wire that lights up with a plug wire that doesn't and see if the problem follows the plug wire.
Reactions: Dart68 and jrichker
5.0ttops87
110
Apr 2, 2017
#10
  • Apr 2, 2017
  • #10
will do.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
  • dan50
  • Jul 18, 2026
dan50
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
