Timing Question
  • Thread starter Thread starter 6T7GTA
  • Start date Start date Jun 2, 2004
6T7GTA
21
  • Jun 2, 2004
'67 FB, 289, Holley 600, mild CompCam, headers. Set timing approx.12-15, runs like crap(especially under load and higher rpm's), set timing around 30, runs great. Question is "has the timing chain slipped a tooth or so"? Any insights?
LMan
1,246
Mom's basement
Jun 2, 2004
  • Jun 2, 2004
are you using a vac advance?
6T7GTA
21
  • Jun 2, 2004
Yes, vac. advance
slapper
447
  • Jun 2, 2004
What does the total timing come in at?
6T7GTA
21
  • Jun 2, 2004
Hard to tell since the marks are worn off after mid-30's.
302 coupe
1,952
Macon, Ga.
Jun 2, 2004
  • Jun 2, 2004
when you set the initial timing(@idle), did you disconnect the vacuum advance? If not, you probably got a bad number. Probably want about 12-14 initial(with vacuum disconnected), then 34 total by about 2800 rpms with vacuum connected.
6T7GTA
21
  • Jun 2, 2004
yes, vac advance was disconnected.
67GTA-FB429
777
Tri-Cities, Wa
Jun 2, 2004
  • Jun 2, 2004
you can try to time it using a vacuum gauge. hook up the gauge and when you get the steadiest number...you are there.
LMan
1,246
Mom's basement
Jun 2, 2004
  • Jun 2, 2004
Something to look at is a vac leak. That can make the motor run poorly at low RPMs as you have a weakened idle signal, while getting better higher up as the increased air velocity overcomes the leak source.
I would do all the usual tricks for vac-leak checking to rule this out.
J
jesserose17
219
Southern CA
Jun 2, 2004
#10
  • Jun 2, 2004
  • #10
Have you checked the dwell?
Max Power
1,774
St Paul
Jun 2, 2004
#11
  • Jun 2, 2004
  • #11
Distributor a tooth off?
D
D.Hearne
11,730
south louisiana
Jun 3, 2004
#12
  • Jun 3, 2004
  • #12
Balancer may have slipped also.
6T7GTA
21
#13
  • Jun 3, 2004
  • #13
Thanks for all the good advice of things to try! I will give them a try!
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
