Timing Question??
  • Thread starter Thread starter TheSlowLX
  • Start date Start date Jun 13, 2005
T
TheSlowLX
44
  • Jun 13, 2005
When I advance my car around 15* - 18* and I come to a stop light or stop, the car begins to surge. Usually at a Stop the car idles around 650 -700 RPMS, steadily. But when I advance the timing, it starts jumping around like 500 to 800 RPMS, and since im on the brakes, it feels like the car wants to move forward, then suddenly it just turns off. Dont get me wrong, when I advance the timing and I floor the car, it feels very strong but the only thing that pisses me off is the part when it turns off at a Stop. Anyone else ever get the same problem? I do have an E-cam with 1.7 RR's, and I always use 93 octane on my car. Anyone have any idea what causes this, or is this just normal? Thanks.
maverick0716
3,924
Chilliwack, BC, Canada
Jun 13, 2005
  • Jun 13, 2005
Try backing the timing off to around 14.....15-18 is a lot.
331 stang91
261
wisconsin
Jun 13, 2005
  • Jun 13, 2005
When you advance the timing you must also check and properly adjust your tps voltage and idle rpm. good luck!!
H
hondakiller44
35
Westerly,RI
Jun 13, 2005
  • Jun 13, 2005
you will need a multimeter to adjust your tps and you will have to adjust your throttle set screw to get the idol you were at before you adjusted the timing.
stang22
1,318
Washington, D.C.
Jun 13, 2005
  • Jun 13, 2005
http://www.dccurrent.com/fbt/tps.htm This will help, if you have never done it before.
Tim
HISSIN50
34
129
Jun 14, 2005
  • Jun 14, 2005
Hmm, not sure I understand the reasoning behind needing to reset the idle after adjusting timing. Please explain further. (I am not being a smarty - I cant think of the reason, but I very easily could be missing something).
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
