  • 1994 - 1995 Specific Tech
Timing Question
  • Thread starter Thread starter Kevin R.
  • Start date Start date Jun 20, 2005
Kevin R.
473
Ohio
Jun 20, 2005
  • Jun 20, 2005
When using the timing light, does it matter which plug you hook the light up to?
Thanks,
SlowGT
826
Columbia Co, PA
Jun 20, 2005
  • Jun 20, 2005
It's normally hooked to #1
1slow95
1,797
ohio
Jun 20, 2005
  • Jun 20, 2005
cobra dave
308
  • Jun 20, 2005
Normally? (not trying to be a smart ass). I've never put a light to anything that wasn't attached to anything other that the #1 cylinder plug wire. It's always front passenger side on v-8's.
bimmertech
1,123
merriam, ks
Jun 20, 2005
  • Jun 20, 2005
yeah i've never tried it, but don't think you could use anything else but 1
HISSIN50
34
129
Jun 20, 2005
  • Jun 20, 2005
And some inductive timing lights have an arrow on the clip to let you know which way the clip should face.
Good luck.
Kevin R.
473
Ohio
Jun 20, 2005
  • Jun 20, 2005
Okay, this timing really confuses me.
Here is what I've picked up from threads and research.
1. Unplug spout
2.Loosen distributor
But im still confused as to what I will be seeing when I point the timing light. Do i point it at the direct top, the side...i duno..does that even matter or will i see the same number from any angle the light is at?
Thanks for puttin up with my noobiness.
R
rocketcarx
9
San Diego
Jun 20, 2005
  • Jun 20, 2005
i wouldn't mess with timming the first time without an experienced helper, man.
Kevin R.
473
Ohio
Jun 20, 2005
  • Jun 20, 2005
Well I understand the basis of it, and i know mostly how, but im down to learn on my own that's why I am asking these questions, so i don't mess it up.
AznStanger3v
2,026
Northern VA
Jun 20, 2005
#10
  • Jun 20, 2005
  • #10
i lean over from the passenger side a little and i get a clean shot on the "time" bracket. Mark what time you want on you balancer with white out or nail polish and turn the dizzy until it gets there. shut down and spout in.
Kevin R.
473
Ohio
Jun 20, 2005
#11
  • Jun 20, 2005
  • #11
Thanks a lot. The "time" bracket is on the balancer correct?
HISSIN50
34
129
Jun 21, 2005
#12
  • Jun 21, 2005
  • #12
For more info on setting timing, click on Tim's site and then hit links and then the timing article.
Good luck.
SlowGT
826
Columbia Co, PA
Jun 21, 2005
#13
  • Jun 21, 2005
  • #13
The timing bracket is attached to the front cover on the passenger's side.
fushnicken
41
NJ
Jun 22, 2005
#14
  • Jun 22, 2005
  • #14
If you want to make your life a little easier.... Get yourself a silver sharpie to mark the balancer at 10deg, 12deg, 14 deg, whatever your looking to advance to. Those little lines can be a pain to see. I marked mine at 10 and 12. Didn't like the way she was running at 12, moved back down to 10.
Happy now.
Markers make it a little more eye friendly, especially when you have to look through all the accessories to see the indicator and balancer.
You should have someone by your side who has done it before and do not forget to put the plug back in after you modify the base timing.
10 degrees made a noticeable difference to me. Some others on the forum go higher. Typically around 12-14.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jun 22, 2005
#15
  • Jun 22, 2005
  • #15
The time bracket mounts to the timing cover, and "surrounds" the balancer. The balancer has marks on it. Get a 1/8" wide WHITE marker and mark 10,12,14 on the balancer.. It will save you a lot of headaches. You should clean the rust off of the balancer first, so the marker stays on it well.
Scott
Kevin R.
473
Ohio
Jun 22, 2005
#16
  • Jun 22, 2005
  • #16
Thank you guys.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
9
1995 5.0 just cranks
  • 9GT5
  • Jun 29, 2025
1994 - 1995 Specific Tech Jun 29, 2025
AeroCoupe
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
J
67 mustang interior courtesy light wiring
  • JCuster
  • Jun 9, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
GypsyR
G
D
shift light
  • dirk shorter
  • Dec 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 29, 2025
