Timing question.....
Well 10 deg. is stock, so advancing initial timing anywhere between 10 and 16 is going to give you better bottom end, but the higher you go the more prone your engine is to detonation and you have to use higher grade gas, which at the moment is outrageously expensive. Also if you increase the timing enough, like closer to the 14-16 range it's a good idea to bump fuel pressure up slightly with and adj. fpr. for best performance results. It's basically the same thing as adding a chip to the computer only it's free.
