TIMING QUESTION
  • Thread starter Thread starter epmustanggt
  • Start date Start date Dec 17, 2006
E
epmustanggt
26
oak harbor wa
Dec 17, 2006
  • Dec 17, 2006
ok i have a 302 with a roller cam setup in my 1966 gt mustang, it has trw forged pistons, trickflow street heat high port heads, edelbrock rpm airgap intake and a holley 4150 650cfm double pumper.
now here is the question, when i go to time my engine i put the timing light on the number one spark plug wire and turn it on at idle (with the vaccum advance off and plugged) and the 0 on my harmonic balencer is at about the 1:00 position with straight up being 12 and facing the floor being 6. the mark on the timing chain cover is way over towards the 2:45 position, so when i try to bring the 0 more toward the mark on the timing chain cover my motor runs like crap. i have no idea why the 0 isnt where it should be.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 17, 2006
  • Dec 17, 2006
I'm not entirely sure what your timing marks look like under the light, but it sounds like you might have a harmonic damper with a slipped outer ring OR the wrong timing pointer, timing cover, or damper.
I have a roller 302 with the early timing cover/water pump and the pointer is on the driver's side and lines up fine with my damper's timing marks.
E
epmustanggt
26
oak harbor wa
Dec 17, 2006
  • Dec 17, 2006
its weird because it runs fine, but just wont line up with the pointer its way more to the left of the pointer, its not even close to being correct looking.
geostang351
946
Danb., CT
Dec 18, 2006
  • Dec 18, 2006
You don't want it to be on 0, you want it somewhere around 12* BTDC
H
HHStang
566
Coastal SC
Dec 18, 2006
  • Dec 18, 2006
try for 36-38 total
Using a light with an advance dial, mark your TDC on the balancer, rev it up to 3k or so on the tach and start turning your dial until the marker and TDC line up and see what your reading is. Advance (turn rotor clockwise) or retard it (counter clock) until you end up with 36-38. You should be starting between 12 and 14 BTDC depending on your cam.
I'm pretty sure I'm telling you the correct info.
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Wanting to replace my BOSS 351C Engine Harmonic Balancer - Questions about 'Balance?'
  • 69machmike
  • Oct 31, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 5, 2024
Realmongo
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
